Question about Acer Aspire L310 (ASL310UD631A) PC Desktop
The ACER tour program wont go away & covers the screen no matter what!
I installed this computer today, had to restore it to a previous date to get it running, and finally got it set up and internet ready.
Now the ACER tour program prepares to download, but keeps running it's light blue box in the middle of the screen! I can run all other programs (& internet), but I have this tour program screen blocking practically the whole moniter!
When I run task manager and close the program, it still stays, and the mouse stays in the "I'm busy - hold on!" animation on that screen (which means I can't move it).
Can someone please help??
  • CassandraMC Feb 18, 2008
    I tried, but the start up screen freezes up once I hit remove or disable. And this big blue box covers most of the screen in the center, so if there's a a small dialog box behind it, I can't see it or move it around the edges. I did a screen shot and emailed it to this computer in my office in case it helps.
    I'm going to keep trying to disable the program in the start up. Thank you for the tip, I'm sure if I can get it to stop freezing I can get this program to shut down.
  • CassandraMC Feb 19, 2008
    When I first started this computer (which by the way is used not new) It said I needed to change the resolution, so I changed it to 1024x780. Otherwise I could only start in safe mode. It does not come up, in safe mode but I couldn't connect to the internet.
    Maybe I should put it back in safe mode and see if I can go to the startup programs in there.....do u think that will work?
    (ps thanks soooo much for your help!)
Press CTRL+ALT+Delete.
If you're using Windows Vista this will bring you to a new prompt screen asking you what you wish to do. Select 'Task Manager'.
You will be returned to the Desktop and the Task Manager will open up on the screen.
Click on the 'Processes' tab on the window, and search through the list until you find something along the lines of... AcerTour.exe
Click on this process to highlight it, and press the 'End Process'
button. (This should immediately close the running process)
Posted on Jun 13, 2008
Im not sure if that would work for sure but also try to go into services tab msconfig, service tab. I will continue to search out a resolution for your problem.
Posted on Feb 19, 2008
    Scholar:
  • 103 Answers
Try going to the command prompt start , run , type in msconfig click on the startup tab and look for that program that starts up and remove the check mark next reboot.
Posted on Feb 18, 2008
  • Jason bates
    Jason bates Feb 19, 2008
    Have you tried to startup in safemode? if you have does that screen still pop up. and what is your screen resolution set at?
Well... yes, I had that problem but I un-installed the tour because it wouldn't run, ever, got stuck, finally it quit appearing! It seems to be one of those tutorials, but it looks also like more up-sales on more and more software. Sometimes more isn't better, it's just more....
So, I google it, and because something in my C drive is always tasking, eats up memory and adds to the start up task as well as shut down time. An article I found called "Zapping the ****" is the first to explain this Vista phenomena, so read this to help you to decide. Hear an expert.
http://computerworld.com/action/article,do?command=viewArticleBasic&articleId=9017702&pageNumber=2
I hope the links works but I would google acer tour, and of course you can always reload the acer tour online if you think your missing something
Posted on Aug 15, 2008
Hi I just bought an Acer Travel Mate 5742 a month ago and its been workin perfectly. Howerver ;today when i switch on I just get the acer desktop screen it does not change to the next screen to...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
May 11, 2011 | Acer Computers & Internet
I have a Toshiba Satellite laptop and it will not open up properly when I turn it on. I though it was that the battery just dies and I plugged it in overnight. However, when Windows Vista says it is...
Treska,
You are lucky. You can atleast boot up in safe mode. While booted in safe mode please go to Start->All Programs->Accessories->System Tools->Restore. Once you reach here, select Restore and a previous date to restore to. The restorable dates are in bold numerals. The system will start the restore process and will reboot once. And your computer will be absolutely fine.
Why it happened to you may be because you installed some program that is clashing with others. So, with restoring to a previous date, you are doing away with that program without actually uninstalling it.
Mar 02, 2011 | Computers & Internet
Restore gone wrong?
I would try and boot into safe mode (F8) and try a different restore point.
If you have a xp disc you can try a repair installation.
You pop the disc in DONT choose to repair, carry on as if you are installing windows, it will search for previous versions and it will offer you the chance to perform a repair installation.
this looks like a full install and takes as long but you dont loose any programs or files.
Jul 10, 2010 | Acer Aspire One PC Notebook
My hp assistant and advisor program stopped working. What should i do?
Do a System Restore to previous Date when it was working fine.
Disclaimer : By doing System Restore you may loose any software/application that you have installed from the date you will restore till today's date. but you wont loose any created Files/documents
Jun 19, 2010 | Computers & Internet
My laptop boots and reboots on its own... When I login it logs the user off
Hello ! i want you to try something re install the operating program on this computer   .the operating program might be corrupted  . thats why its behaving that way  .also run an anti virus  to check the hard disk for program infections .ie before X P installation .
best of luck
Aug 04, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Whymy buil in acer cryatal eye webcam doesnt work? 'camera not found' is always in d screen whenever i click it, and when i use it with videochatting d screen is all black.help!i have an acer 2930Z.
First of all try re-installing the webcam driver [better if you remove the previous installation first] Second try restoring windows to an earlier date prior to your issue.[START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE].
Jul 13, 2009 | Computers & Internet
Dear reader; I bought hunting unlimited 2008, its been playing fine, today I went to play it and I can't seem to get it playing
You may restore you system to a previous date. Choose the date when it was working fine. Just go back a day or 2.
Steps
Start>All Programs>Accessories>System Tools>System restore>Restore to Earlier date.
When you restore to a particular date. the softwares loaded after that particular date wont be there. So be careful and dont go too far back.
Hope this will help
Regards
Sammy
Aug 31, 2008 | Computers & Internet
Start up-acer manager
try using a system restore
go to start>all programs>accessories>system tools>system restore. choose a date when your computer worked perfectly well or before the date you installed any new program or updates
May 09, 2008 | Acer Aspire 5100-5022 Notebook
Acer orbi cam not working
Best is to do system restore.System restore is under
Program--accessories-->system tools.
With system restore you can go back to previous date your cam was working fine.Its just like a time machine.So try to back to the previous date and check out which date make the cam work.
Give it sometime to config and maybe it have to restart your computer.
Best of luck,takecare.
Apr 27, 2008 | Acer Aspire 5630 Notebook
Acer Aspire  L310 (ASL310UD631A) PC Desktop Logo
1,287 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
