Question about Altec Lansing ACS 295 Computer Speakers
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
    Genius:
  • 1,121 Answers
If connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Posted on Jan 30, 2010
Need new system input cable for acoustimass 10
I've made a diagram of my serial cable. You can easily make one with some speaker wire and a 15-pin d-type female serial connector. Solder the wires as shown in the diagram.
Jan 26, 2010 | Bose Acoustimass 10 III System
Speaker cable installation
1.  Check the orange multipin connector for bent or broken pins.
2.  Make you have the subwoofer plugged in to a live power outlet.
3.  Check the fuse on the circuit board inside the subwoofer.
4.  Measure the output of the subwoofer power transformer.  I think I remember it as being in the range of 12-24VAC.  Inspect the rectifier diodes for signs of overload.  measure the dc output of the diodes.  I think I remember 18VDC.
5.  Open the right speaker and verify the on/off switch is working.
6.  New Egg sells a multitude of similar speakers in the $40 to $80 range.
Apr 04, 2009 | Dell HK395 Computer Speakers
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
How to make a 15 pin female sound in cable
Ya, here is a diagram I made of my Acoustimass 10 IV input cable. All you need is a female 15-pin d-type connector and a bunch of speaker cable (also one RCA connector for sub connection). Here's my diagram:
Mar 10, 2009 | Bose Acoustimass 10 III System
My sound in cable was missplase and can i make it my self and pls any body can send me the cable structre. pls...........
Here's a diagram of the 15-pin serial input cable that came with my Acoustimass 10 IV system. You just need a 15-pin female d-type connector, one RCA connector and a lot of speaker wire. Here's my diagram:
Broken orange plug on right speaker going into subwoofer
Other posters to this forum have said this connector is available at Radio Shack.  If you can't find a connector here is a workaround that will do the job:
If there is a broken pin you can bypass it by cutting open the cable jacket and delicately soldering a 6 inch or so jumper onto the affected wire, and then  solder a jumper to the appropriate point inside the subwoofer. Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
Dec 02, 2008 | Dell HK395 Computer Speakers
Dell HK 395 Speaker System - Need Circuit Diagram Download
1.  Check the orange multi-pin connector the sufwoofer for a broken or bent pin.  If there is a broken pin you can bypass it by cutting open the cable jacket and tap onto the affected wire with a 6 inch or so jumper, and then attach a jumper to the appropriate point inside the subwoofer.  Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
2.  Try wiggling and rapidly rotating the volume control.   There are reports this control may become a problem as it ages.
3. I haven't been able to find a schematic.  My only recourse was to google the output amp and the 2 op-amp packages for data sheets.  They are readily on the internet.  Then I laboriously traced out the stereo paths.  I found that red and black fine tip felt pens were helpful in marking out the signal paths through the circuit boards.
Nov 21, 2008 | Dell HK395 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Altec Lancing Multimedia Computer Speaker System ACS295
yeah. dude go to radio shack or a similar equivelent and they'll have all the parts as well as the instructions or even the abilities to fix it right there. Try it!
Nov 13, 2007 | Audio Players & Recorders
940 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
