Question about Canon PIXMA MP460 All-In-One InkJet Printer
My canon all in one mp460 is pulling the paper in crooked (it seems to only be pulling it in on the right side when i try to print), it is then getting jammed,and then error: theres no paper reload and hit ok.
  • a_rittorno Jan 30, 2010
    my canon all in one mp460 is pulling the paper in crooked (it seems to only be pulling it in on the right side when i try to print), it is then getting jammed,and then error: theres no paper reload and hit ok.
    Do you have any recommendations as to where i can bring it and about how much it will cost? Or is this something i could go buy and do myself? Ive looked up some places by me and they all look like they are for big businesses. I live in Chicago, IL. My zip is 60607. Thanks.
    Alyssa
  • 542 Answers
This clearly shows that paper feeder/out roller is having the issue. Repair/replace the rollers will solve your problem.
Revert back for assistance.
Posted on Jan 30, 2010
  • Rajesh Pai
    Rajesh Pai Jan 30, 2010
    I mean right side rollers may having the problem. check and replace the same will solve your problem.
    Revert back for more assistance.
  • Rajesh Pai
    You cannot change the faulty rollers by your self. Replace the same with help of expert engineers/service center experts.
Mp460 feeds more than one pages
Hi ...
There is no hardware fault in this perticular situation. This happens because of paper loaded. There are 2 possible resolution to this problem:
I) Fan paper prior to inserting it into the MP460
  1. Remove paper from the ASF.
  2. Open the paper output tray. (See <2> in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See <3> in Figure 1 below.)
    Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    * Figure 1
    The illustration shows the PIXMA MP460
  4. Fan out the sheets of paper so that they do not stick together.
  5. Load paper in the auto sheet feeder with the paper's print side facing up. (See <1> in Figure 2 below.)
  6. Align paper to the right edge of the auto sheet feeder. (See <2> in Figure 2 below.)
  7. Pinch and slide the paper guide to the paper's left side. (See <3> in Figure 2 below.)
    * Figure 2
II) Load fewer sheets into the MP460
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 feeds the paper into the printer crooked. Seems to be feeding right side in, while left side of paper remains stable.
I just got mine sorted out. It took two things:
a. luck
b. a lot of googling
Now,
The problem was 15 cents of the Euro in the following configuration: 1x10cent coin and 1x 5 cent coin...
The first thing I did was try to clean the bottom plate and the roller. I read somewhere that using some thick paper does the trick. I destroyed an office paper file (not very thick, but definately thicker than normal papers) - about 5 - 6 tries on the bottom plate clean and the roller clean, and a 5 cent coin appeared out of nowhere :)
I though that was it but I was very very wrong. At about the same time, I got the mother of all annoying canon error 5100. Although the heads moved at starting of the printer, when it came to print it had the error. I looked as much as I could and I was convinced (several times) that there was nothing in the printer. The heads moved fine, but the error was there. Rebooted the printer about 50 times, took power off etc, but nothing.
After a good 5' search with the flashlight (mobile phone) I spotted a small shine right where the little spongy thing is under where the heads rest far right when you look inside from the front of the printer. And voila, a 10 cent coin standing glorious in there and causing me all this trouble. I couldnt access it at all, but I was able to use the force of gravity (by inverting and giving a little jiggle to the printer) to get it to drop and finally got it out.
The printer works fine now, paper loads like a charm and even colour photo printing is fine.
Now I need to find a way to put back that little plate I took out (totally unecessary in the end...) and I have to sort out the removal of tons of ink from my hands.
To sum up:
It can be fixed. It's a pain in the ****. You might get richer (15cents for me!!!). You will have a full functioning MP460 printer again.
I hope this helps someone else as well :)
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Feb 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper pulling to one side
check the paper feeder if there are things blocking one side of paper loading.if so, remove it then try printing.
Jan 09, 2009 | Canon I960 InkJet Photo Printer
Canon MP460 "np paper"
Canon PIXMA MP460 error code 5010
Sep 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460
check for obstruction and paper thickness lever on the printer and try printing again.
Apr 14, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Duplex printing won't work
There is no duplex on this printer, two sided printing is only achieved via manual feeding, I checked the canon website spec for the MP460
Oct 09, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Paper Jam!!--Only one side pulls
Call Canon. I'm on the hold with them at the moment... Just finished speaking with them. They are sending me out a new printer, free of charge and including ups shipping label to send back to them. Sending the one I have back in the new box. Give them a call. They were really helpful and tool all of 5 minutes. Good luck. Kim
Apr 30, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
