Question about Maytag Dryers
Hello, we have your Maytag Model #LDE712, Serial #602558 and there is no power at all. Just wondered where the fuses are located and what type of fuse it requires. Thanks for your help. We do hope to get many more years of service from this very good Maytag dryer. Sincerely....Mary
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
This dryer has a fuse located on the blower housing. replace and check for proper air flow. take front panel off.
Posted on Jan 31, 2010
Why doesn't my Maytag dryer model LDE712 heat. All things related to check have continuity.
Sometimes you have to disconnect elements of the heating system to check continuity ('element's' as in 'parts of').
Can only be 4 things
Element
high limit thermostat
high limit cut out
mainboard/switch
Feb 05, 2016 | Maytag Dryers
What do i do with a f9-2 error and oven door is lock?
Hello, Ms. Perez. My name is Melanie and I am a representative of Maytag. I am sorry to learn about the problems you are having with your range. Turn off the power to the range by pulling the circuit breaker for one minute, then turn it back on. Then try to turn the self clean on, then turn hit cancel before one minute. That should unlock the door, and remove the error code. If my suggestion is not helpful, and you still need assistance, please provide your name, you phone number, your address where the appliance is located, full model and serial number, and email this information to Maytag.Digital@maytag.com. We would be happy to look into your concern further. Sincerely, Melanie.
Apr 06, 2012 | Maytag MER6772 Gemini Electric Kitchen...
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Display does not light up at all
If the 120VAC wahser service outlet has power and the machine LED Control Console for the FAV6800AW or LCD screen for the FAV9800AW appeares to have no power then I feel you have a Control Board failure. If you post your model number we can give you and aproxmate cost of the Control Board. The Control Board is under warranty for 5 yr. If you call Maytag customer service at 1-800-688-9900 they will need your Model Number and Serial number located on the rear top right of the console.
The above machine types do not have an internal fuse or circuit breaker to check.
Nov 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
LIGHTS COME ON BUT WILL NOT RUN
Are there any error codes to the LED display when you press the Start button of your FAV6800AW is that your model? Error codes types such as OD, OP, FL,LR etc.
Have you tried to power cycle the machine by pulling the 120VAC power cord then re-power back up. If there are no error codes the next step would be to enter service mode and read the machines diagnostic error code list to get a start point for troubleshooting.
I’ll assume the machine type is a FAV6800AW or FAV9800AW and post some handy links. If you want to DIY I will try to help. If you decide to call in a service repair company I would call Maytag for an authorized Maytag repair service in your area some parts Like the Control Board may still be under warranty (5yr). Warranty info is in the SM link I attached. The number to call is 800-688-9900. Maytag will need your model number and serial number, that info is located on the back right top side of the console.
The Service Manual for reference. Sears Parts Direct for reference.
Oct 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I was wanting to know the year of the maytag neptune washer? model # MAH5500BWW
Try and get the serial number then contact a Maytag agent. The serial number in most cases is a date code.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Dryer will not start and it has power to it.
Hello jmhbfdtk4,
If your dryer has power and will not start when you press the start button, you may have an interlock that isn't made to allow it to start. It could be the door switch, a non-resettable fuse inside the dryer or something else. Are you getting any error messages on the system? Please advise and I will follow along with you...
Regards,
Rick
Nov 23, 2008 | Dryers
Dryers Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
