Question about Kenmore Dishwashers
Kenmore 17795 water wont drain I have removed the lower dpray arm & found alid wedged near the drain i removed it & cleaned around it but water still wont drain
5 Suggested Answers
SOURCE: Kenmore ultra wash III dishwasher
Well, the water is clean. The only thing I can think of is that the pump is just not doing its job. The only way to know is put a meter or a flow meter on the pump but heck, I can buy a new dishwasher for under $300 so I think I will just give up. Hate to do it but it is not worth the time and effort anymore. I really appreciate your involvement in my problem and I hope I have not over loaded you with my questions. New dishwasher, here I come........ bah humbug. Mine was only 13 years old, they just do not make them like they use to.
Posted on Jul 12, 2008
SOURCE: Kenmore dish washer wont drain
Those are Chinese massage balls. You place them in your palm and rub them together and the result is a "calming" effect, which are ingeniously placed their by the courteous engineers at Kenmore to help you relax while you perform the self-repair. Just kidding. I had the same problem and learned that they are called "float balls". There should a small hole where the water comes up and drains - they are placed in that hole.
Posted on Nov 27, 2008
danromarris
  • 101 Answers
SOURCE: Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
  • 583 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
How to Check the Spray Arms Home > How To > Appliance > Dishwasher >Check 1x1.gif Caution: Please read our safety information before attempting any testing or repairs.
The pump/motor assembly pumps water up through the spray arms. The force of the water cause the arms to spin and spray the water and detergent mixture into the dish and glass racks. Some dishwashers have just one spray arm at the bottom in the tub, others have a second spray arm under or over the glass rack. Some dishwashers also have a spray tower that rises up out of the lower spray arm to concentrate an additional blast of water.
To access the bottom spray arm, remove the bottom dish rack. Reach in and spin the spray arms. They should spin freely. Lift up the spray arm from the end. There should some play in the arm allowing you to wobble it up and down. Inspect the seams of the arms for splits. If water sprays out of a seam, the dishes will not receive an adequate spray for proper cleansing and the force of the water directed at the door may cause leakage.
The lower spray arm may also have a spray tower. If it does, pull up the center part of it as far as it will extend and let it drop. It should lift and drop smoothly. You can also unscrew the tower by hand to inspect the interior for foreign objects that might clog it.
Remove the upper glass rack as necessary to access the upper spray arm. Repeat the steps above for the lower spray arm. The upper arm may not have as much wobble as the lower arm.
The water source for upper spray arm on some dishwashers may be through a tube which mates with the spray arm when the rack is pushed all the way back. Make sure that the rack is properly aligned with the water supply tube.
If necessary, the spray arm can be removed for cleaning or replacement. Unscrew the spray tower (if any) by hand and remove the bolt (if any) in the center of the spray arm. Otherwise lift and rock the spray arm until it comes off. Keep any washers in the same order as they are removed. To clean, soak it in warm water and rinse with a vigorous spray.
Posted on Mar 20, 2009
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Kenmore Dishwasher is not draining... checked drain line at disposal..not it. Have diassembled much of the housing at bottom of tub but still can't get to drain. Any suggestions?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore Dishwashers
Dishwasher wont drain!
Hi
Daniel
Aug 22, 2011 | Kenmore Dishwashers
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
It doesn't drain all of the water out after cycle is complete
Hi and welcome to FixYa, I am Kelly.
Dishes not getting clean is caused by either a restricted drain, (usually the problem) or larger than usual particulate under the lower wash arm tower.
The restricted drain can manifest itself:
- At the pump outlet, (remove hose and inspect drain port)
- At the air gap at the sink (remove cover by lifting straight up then unscrew the inner cap nut and remove the particulate) NOTE the installed position of the upper cap under the nut as it will only go back together in one position)
- At the Air Gap outlet hose connection (remove hose and inspect plastic tubing)
- At the sink connection. This can be either a direct plumbing connection or a garbage disposal connection. (remove the hose and inspect drain connection.)
As far as the lower wash arm tower
- Remove the lower wash arm.... NOTE the stack up of parts... it only goes together one way!!!!
- Remove the lower wash arm tower screws
- Lift off the lower wash arm tower and clean the screen area.
- Remove the screen and check in the pump impeller area for a broken impeller or damaged pump housing.
I really need the long model number if you need further assistance. The model number will look like this 220.13599000 but the numbers could be something much different. (This example is for Kenmore)
Thanks for choosing FixYa
Kelly
Jan 16, 2011 | Dishwashers
Elite will not drain
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Oct 08, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Sep 26, 2009 | Maytag MDB5100A Dishwasher
Lower spray arm will not spray water
I just had a simliar problem with all spray arms and solved the problem by cleaning the food screen. Basically, it takes water pressure to make the spray arms rotate. Before assuming there is a failed part, make sure the spray arms are getting max water pressure by checking the food screen. Here's how I serviced my Kenmore dishwasher.
The lower arm assembley is removable by twisting the center plastic piece. It's not very tight and should come off easily by twist with a pliers (but gently). Then remove the tubing to the upper arms (Two screws). Then remove the bottom drain cover (4 star screws).
Under the drain cover are two more things to remove. One, a plastic plate over the bottom of the water drain (1 screw). Two cover to the food screen (1 screw). After removng the screw to the cover of the food screen, it will be a little difficult to remove that cover. The side opposite the screw requires releasing a catch with a screw driver. It's hard tell which way it releases, just keep trying different ways until it pops up. The cover may stick a little beacuse of the food stuck in the screen.
Once you have access to the screen, the screen can be removed by pulling on the center shaft (spring loaded) with a needle nose pliers and lifting the screen straight up. (Note: there maybe a blade next to the screen used to braek up the food.)
After removing the screen, clean it (I used a plastic scrub brush).
Reassembly is performaing these steps in the reverse order.
Hope this helps!
Mar 04, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Whining noise with Kenmore 16032 dishwasher
I had a similar issue, I removed the lower spray arm (had to hold center plastic tab with pliers and then unscrewed and lifted up the arm). Then I removed the cover with the screen filter(4 screws) and then removed the top half of the stainless chopper housing (1 screw). Found that things like cherry pits, elastic bands, bread plastic ties had blocked the water inlet to the chopper and the area around the chopper blade. Cleaned it all up, reassembled and machine works great! Mine was so blocked that I was hardly getting any water pressure to the upper rack.
Mar 11, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore ultrawash dishwasher
To clean the drain on the inside of the tub area you must take the upper and lower racks out first. The lower just slides out and the upper needs the plastic end caps removed from the guides. Next are the two Phillip head screws from the water tube that distributes water to the middle and upper spray arms. This just snaps into the tube behind the lower spray arm. Removal of the lower spray arm is a little tricky. Hold the spray arm and with a pair of needle nose pliers turn the spayed sticking up in the middle of the top of the lower spray arm clock wise. Careful, the spayed piece is plastic. Yes you will think it is the other way but it is not. Remove the lower spray arm. There are (4) four # 20 Torx™ head screws that need to be removed. This will remove the water shed cover. Then there is a #15 Torx™ head screw that covers the waste disposal auger and disposal screen. That is where the clog usually is on the inside of the machine making it not drain properly. I would clean all of the pieces and reassemble in reverse. After that you should run the machine twice and listen to make sure that the water is filling and draining properly. This will also remove all the built up soap residue from it not draining properly.
I had the paper from tea bags, a couple of pieces of un-popped pop corn, a tooth pick, two twist ties from bread and a Barbie necklace clogging my machine. Imagine that!
Sep 12, 2007 | Dishwashers
Dishwashers Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
