Question about Whirlpool GH7208XR Convection / Microwave Oven
Whirlpool microwave gh7208xrq totally dead 20amp
Whirlpool microwave gh7208xrq totally dead 20amp fuse is good what else could be wrong
  • Whirlpool Master
  • 9,098 Answers
In many Whirlpool models, there are several fuse and thermal cutouts (TCOs) / thermostats.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 31, 2010
Inconsistent power
If it's totally dead, the main fuse may have blown. However, since it was inconsistent before it went dead, it might lead me to think that you have a loose connection. Sometimes they heat, lose continuity, and then work again when they cool. A defective thermal protector might also cause this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Dec 20, 2013 | Whirlpool WMH1163XVS Microwave Oven
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
No power, power at receptical,20amp fuse good
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 14, 2011 | Whirlpool MH7140XF Microwave Oven
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Dead Microwave - Internal Fuse?
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
Jan 23, 2010 | KitchenAid KHHS179LSS Convection /...
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jan 03, 2008 | Microwave Ovens
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Mike
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Whirlpool GH7208XR Convection / Microwave Oven Logo
298 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
