Question about Kenmore 61684 Microwave Oven
Upon startup, on high power, trips the circuit breaker. The microwave is on a dedicated 20 amp breaker. It's a recent vintage (2007) Kenmore unit, installed over a cooktop with the built in exhaust fan. I don't know the model number.
  • Kenmore Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. See here.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer. See here.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See this file.
You can find exploded views and order parts by entering your model number (from the tag in or on the unit) at the Sears parts site.
BUT once you have the part number from the Sears site, you can often get the parts cheaper here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jan 31, 2010
Testimonial: "This was great, MicrowaveSvc gets an A+. Thanks very much."
I don't have a dedicated circuit for a only microwave oven use only. Is this necessary?
no
microwave ovens are a plug -in unit and be plugged into any socket (GPO outlet) that has the correct voltage for the unit
Jan 04, 2017 | Microwave Ovens
We have a kenmore microwave oven & keeps tripping our breaker switch. Its not even a year old. What is the problem?
Your microwave should be on a 20 amp dedicated circuit. Often people add these later after initial construction and do not have an isolated circuit for it. If you have this on a circuit with other outlets or possibly the refrigerator, this can cause the circuit overload and trip your breaker. Try running an extension cord from another circuit that is not being used such as outlets, but not GFI outlets! and see if your microwave operates then. If not you have an internal issue with the microwave and it could be a defective Magnetron or doorswitch assy causing the problem.
Aug 14, 2014 | Microwave Ovens
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Model #JES2251SJ02 trips immediately 20 amp circuit breaker. How many amps does this microwave need to work properly?
I called Public Service and they suggested either a dedicated line or upping tha amps of that c-breaker. I need to call an electrician to help me decide which is best for my house.
Aug 20, 2008 | GE Microwave Ovens
Kenmore 61684 Microwave Oven Logo
121 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
