Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
My wireless router netgear is not transmitting the internet signal what can i do to fix it. I have tried resetting the factory button on the back and securing the wires in their correct places.
  • 3,866 Answers
There is a little hole on the back to reset the router you need a paper clip to push and hold that.
Hold it in for 5 to 10 seconds until the light go off then blink.
Also reset you isp modem as well by unplugging it from the ac outlet
allow you modem to come up then reset the router.
if it still does not work you might have a issue with the router but please do try these steps.
Thanks and please rate using the 4 thumbs above.
Posted on Jan 30, 2010
How to reset rangemax wireless-n 150 router?
Reset means that you will restore it to factory defaults which will delete all of the configuration settings of the router and will leave you not connecting to internet and wireless as well, but if you really want to reset it, just simply press the black button at the bottom of the N-150 router, press and hold it for at least 15 seconds. Once the lights on the router starts blinking, that means that it is successfully restored to factory defaults.
Dec 25, 2011 | NetGear Computers & Internet
How to set netgear router WNDS3400 to factory settings
If you would like to reset the router to default settings then please perform the below steps:
With the help of a paper clip, press the reset button on the back of the router for 20 seconds (please refer to the label on the bottom of the router for reset button location). Release the reset button after 20 seconds and turn off the router. Turn the router on after few seconds.
Please reconfigure the router using its default credentials mentioned on the bottom panel of the unit.
Regards
Anand
Nov 21, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Lost my password
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password.Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router Reset for most routers with a reset button on the rear panelWrite down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Sep 20, 2011 | NetGear WGR614 Wireless Router
I have a netgear router WGR614v9 . I forgot its password. I can not connect any computer to internet. How do i reset the password?
There should be a reset button at the back of your Netgear router. Press it for 10-30 seconds and that should reset it back to factory settings.
Cheers!
Angel
Jul 08, 2010 | NetGear WGR614 Wireless Router
My rangemax router keeps reverting back to no signal, I unplug it from the cord that goes to my internet service for a few minutes plug it back in works for about 10 minutes then goes back to no signal...
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need to reset netgear router wpn824v2
Don't tell me you tried to upload the firmware from a wireless connection.
It's probably bricked. You could act stupid and send it back to Netgear, claiming it just died...(it did right?) and in the meanwhile, Staples is selling 624's for $40 this week.
Carl
Jul 05, 2009 | NetGear RangeMax WPN824 Wireless Router
How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
WGT624 v3 transmits no wireless signal.
You have to set up your router again. The id will be "admin" the password "password".
See manual" http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Feb 19, 2009 | NetGear WGT624 Wireless Router
Netgear help
well you can reset to factory and start over , press the reset button on back for 10 sec.
you shouldnt have to set anything except wireless security.
Mar 03, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
294 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
