Question about Sony CPD G500 21" CRT Monitor
Sony CPD-G500 w/odd brightness problem. 2dim w/text but hi-rez ok
Sony CPD-G500 with odd brightness problem. Too dim on text modes and lower rez, and much brighter on higher resolutions.
Text modes and low rez can't always be made bright enough to read even with 100% brightness.
Higher rez modes like 1600x1200 are so bright they blur unless brightness is set to 50% or lower.
SOURCE: problems with the monitor's brightness...
1 it is due to low voltage on crt pins. 2 if it is ok check video section 3 crt might be weak if monitor is old.
Posted on Sep 26, 2007
  • 100 Answers
SOURCE: bright blue spots on lower right corner of Sony Grand WEGA KF50WE610 50 in. Rear projection tv
The spots are from dust in the optical assy. It would need to be replaced because the only way to fix the part would be to disasemble it in a dust free room.
Posted on Oct 31, 2007
Shuttle83
  • 1139 Answers
SOURCE: sony kf60we610 brightness problems
The problem might be with the circuitry driving the LCD screen. Since the back lighting blub has been changed the only thing that could cause this issue would be the screen brightness which is controlled by the LCD circuitry. You will need the schematic to aid you in the measuring of these voltage values.
Posted on Nov 15, 2007
kevin000
  • 1847 Answers
SOURCE: Bulb Life
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 17, 2008
skotkolr
  • 558 Answers
SOURCE: Cannot go over 1600x1200 resolution
did you get info with the graphics card? not all can go high some are lower resolution for reasons.
and be aware that monitors can not go up in resolution forever they have a max limit so based on frequency you are using you may only get 1600 x 1200 1650 x 1080 is as high as this card will go it is listed on the side bar here under editors choice.
based on monitors freq settings you may need to adjust that to get to the max
http://www.sapphiretech.com/us/products/products_overview.php?gpid=261&grp=3
Posted on Mar 22, 2009
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
My high beam switch won't stay clicked onto bright lights I have dims - but the lever won't keep my brights on. I can hold the lever forward and I have brights - but when I release the lever, I go back...
Try turning the headlight control knob clockwise so that the arrow is pointing up. You may only have it in daytime lights mode and not actually in headlight mode.
Dec 24, 2010 | 2005 Volvo S60
Hi i have a soney vaio, and when the compter
Does it do this on the wall power supply?, I suspect not?, It may well be in the Power Settings for the system, but if on battery sometimes the screen dulls right down to save battery, and the lower th battery the duller the screen... If at home, it really should be plugged into the adapter, and really only used off adapter when out, not near power. The power settings ACPI and used by Windows. seems to be to dowith it as you say BEFORE Windows loads, it is OK, after it is not, so it must be a Windows setting?
Mar 10, 2010 | Sony VAIO VGN-N365E/B Notebook
From long run my monitor contract has weaken and I am getting yelloies colour on full brightness and contrast How to increase and how to make it whiten ?
Hey, try to increese the brightness from you display adapter settings on the pc. Sorry to say but its time for a new monitor.
God Luck.
Jan 25, 2010 | Sony CPD 20SF2 (White) 20 in.CRT...
Cannot see screen
to adjust brightness.
on the menu screen,
Touch the "star" at the side of tools,
touch "minus" or "plus" sign to adjust,
touch ok,
or, tools-system-color mode
set this to auto for best performance.
Regards.
Apr 11, 2009 | Garmin StreetPilot c340 GPS Receiver
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
G500 driver
Dear shantz
Please find the unified driver for all Windows 98/ME/2000/XP at the following link.
http://www.nodevice.com/driver/G500/get40219.html
Please Press the verification code (simple) and click download. Your download will start automatically in 30 seconds.
Regards.
Please dont forget to rate this solution! Thanks
Apr 01, 2008 | Sony CPD G500 21" CRT Monitor
Sony CPD E500 - Power On from cold problem
as u told ur monitor is excellent only... it is in good condition no problem will be there ... may be there is problem with the operating system just try reinstalling it... ur problem will be solved...
Feb 05, 2008 | Sony CPD E500 (White) 21" CRT Monitor
Broken power button
Just take the PCB out of the unit, if its a mechanical switch just hit it and leave it on and reassemble, if its a push button switch just drill a hole next to the switch and use a non metalic object to turn the unit on :-)
Sep 14, 2007 | Sony CPD G500 21" CRT Monitor
Problems with the monitor's brightness...
Sep 09, 2007 | Sony CPD E100 15" CRT Monitor
Sony CPD G500 21" CRT Monitor Logo
83 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
