Question about Kenmore Washing Machines
Kenmore washer is only letting in cold water on hot cycle. there is plenty of hot water at sink next to machine so it is not the water heater.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
TRY TO MAKE SURE SCRENS ARE NOT CLOGED
Posted on Jan 30, 2010
Purchased in 2003. Dishes were exquisitly clean till 2008. Our water heater temp was set at 140 temp. This heater was replaced with a heater now set at 125 temp. In the past two years dishes are nowhere as...
try turning on your water at the sink for a while on hot let it run then start the wash cycle that should help. what that will do is let the cold water run out of the pipes and therefore you will have a hot water start.
Dec 17, 2010 | Kenmore Dishwashers
It is saying LFduring a wash cycle
LF is for long fill . First thing to check is turn off the water supply hot and cold to the washer. remove the fill hoses from the back of washing machine.looking at the hose inlets on the machine you will see a small screen in each opening with a small pick or other small tool carefully pry out the screens and clean them in the sink. then reinstall . Do not leave out or damage to the valve could result ..The cold water side will be dirtyer than the hot because most of the debris in the hot water side is caught in the hot water heater.. Let me know if you continue to have a concern
Aug 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 80 series washing machine - cannot get
Hi and welcome to FixYa. I am Kelly. This sounds like either the hose or the water inlet valve screen is clogged. Possibly the pinhole inthe diaphram itself of the water valve. Here is what you can do.
1. Get a bucket
2. Turn off BOTH water valves at the wall.
3. Remove the HOT water connection at the water valve. Then check the inlet screen for debris. You can remove the screen from the water valve by using a knife blade on the very outside edge of the screen tugging outward. Hold the screen up to the light check it for debris. If it is dirty wash it under a light flow of water in the sink. DO NOT reinstall just screen just yet.
4. Use a measuring cup or something similar to catch water at the water valve HOT connection. Select a WARM wash cycle and start the wash cycle. Let the water flow into what ever it is you use to catch the water exiting the HOT water connection.
Tap on the cold water hose connection to try and free the debris inside the water valve as the water is flowing. Do this a few times until you have let water back flow through the water valve for about 20 seconds.
Machine timer off.
5. Reinstall the inlet screen in the water valve and reconnect the hose. Place the HOT water hose in the bucket and start the WARM fill cycle again. This will flush the hose.
Machine timer off.
6. Reconnect the hose at the wall connection and turn on the water at the wall.
7. Select HOT wash and test water flow. It should by now be (fingers crossed) flowing.
You can repeat the above for the cold water side if you need to.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Hot/cold cycle works but w/out hot water
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
Ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Mar 05, 2009 | Kenmore Washing Machines
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
