Question about Whirlpool Refrigerators
Have a Whirlpool ED5PHAXSoo1 side by side. The metal between the doors is very warm to the touch
  • 4,059 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Posted on Jan 30, 2010
The metal between the fridge and freezer compartments is HOT
thats complete;y normal especially if it runs a lot or you open and close the door a lot in a warm and humid climate
May 31, 2010 | Sub-Zero 695/O Side by Side Refrigerator
My whirlpool gold side by side is extremely warm bordering on hot when you touch the upright section between the fridge and freezer, (where the doors meet)
As long as it doesnt affect cooling operation, this will be normal. There is a heater in that area meant to keep the door gasket from building frost. Without it the door gasket wont properly stick giving you that air tight seal.
Mar 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door was left open. First the freezer went warm now the fridge. Motor is still running.
you should verify if the compressor is actually running,done so by removing back panel....the whirlpool units are notorious for shorted compressor relay issues...listen for a hum and a click coming from compressor,also compressor is usually hot to the touch if relay is shorted
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
What would cause the metal face between the doors of a side by side to be extremly hot to the touch?
A condensation heater is located in this panel to prevent moisture from forming.
Some refrigerators have a energy saver switch that when selected will turn this heater off.
Apr 12, 2009 | Whirlpool Refrigerators
Inside the door panel
If you mean the area where the gasket is...yes.  This is a mullion heater designed to prevent freezing the gasket to the box.  It should be slightly warm.  Some units have the option of turning thi feature off.  Check your manual.
Nov 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool sideby side
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
May 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
