Question about Sta Rite Dyna Glass 1.5 H.P. 115/230 Pump
Increase in noise which is difficult to describe. loud constant shrieking noise. does remind me of failing bearings.. not leaking but i dont know if its the pump or the motor. about 15 yrs old at this point with moderate use (6-8 hrs/day) do i need a new motor or should i rebuild the pump unit? thanks anyone jim
  • 1,675 Answers
Sounds like the bearings m8 would be better to replace pump as bearings in these type of units are sealed sorry not much help.
Posted on Jan 30, 2010
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
What could be causing the loud shrieking noise on spin only? It's also making a little bumping noise - not a lot, but it's there.
It is usually the bearings that cause the shrieking noise if you have a belt on it it could be needing straightened on the pulley and if you take the belt off and try and turn the drum and listen to see if it is the bearings slightly grinding they may have got water into them. The only other unit is the motor. The bumping noise can be caused if maybe a sock or something that can get between the drum and the casing also some washing machines have shockers and some have springs on top that can break through time and wear and this causes it to be unbalanced.
Mar 14, 2016 | Washing Machines
Have whining noise in rear end sounds like power steering noise, when turning left or slowing down
I would check the carrier bearing on the drive shaft. If that is Okay what you have described would suggest a bearing in the rear end. But I would check both sides wheel bearings. for leakage if one side is leaking it might just be a bad bearing on one side or the other.
Sep 17, 2014 | 2004 Dodge Ram 1500
2002 aztek
If the noise sounds like a roar or growl increasing with speed, may come and go depending on turning left or right then you have a wheel bearing that has failed ( example; loud on right turn=left bearing as it is now loaded)
May 03, 2014 | Pontiac Aztek Cars & Trucks
Noise like rumbling tires in 2004 honda civic EX
hi
if the noise is there and it get loud as the speed increase
then check your wheel bearing.
Jul 06, 2017 | Honda Civic Cars & Trucks
Experiencing loud road noise constantly but gets louder when turning left. Any ideas?
yes the loud road noise would be a front wheel bearing i check these by jacking the car and on stands then spin wheel by hand and other hand hold on the strut spring when feel a hard drag or meatlal to meatal feel that is the bad wheel bearing good luck
Feb 14, 2011 | 2004 Chrysler Sebring
Loud knocking noise with increased resistance
Sounds like you a bearing in flywheel is failing need to call Accell Fitness of North America @ Phone: 1-800-667-1020 they are the distributors of Tunturi equipment
May 03, 2010 | Exercise & Fitness
When making a left-hand turn, a loud grating noising comes from the passenger side front wheel assembly. The frequency of the noise increases with speed, and the intensity of the noise increases with the...
ck the CV boot. if its broken you need a new cv axle, if its ok, jack up the car so both wheels are off the ground. either put the car in drive or just manually spin each front wheel while gripping the coil spring for the front strut. if you feel any (roughness) at all, that wheel bearing is bad. it should be smooth. if you have a bad one you will know it by this method. Even good mechanics sometimes replace the wrong bearing, but this 100% works every time.
Sep 18, 2009 | 1995 Nissan Maxima
Sta Rite Dyna Glass 1.5 H.P. 115/230 Pump Logo
160 people viewed this question
Top Sta Rite Garden Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
