Heater turns on for about 5-10 seconds then shuts down
  • mendezcantu Jan 31, 2010
    Did that what else can i do, would any one know where to get parts I live in Houston 77015
  • 767 Answers
Well depending on the type of heater it sounds like the flame sensor needs to be cleaned or replaced. There is a rod that sits in the flame that has a single wire connected to it. Pull the flame sensor out and clean it with a piece of light grit sand paper or emery cloth and put it back in and the furnace should sustain flame.
Posted on Jan 30, 2010
  • Heath Moyer Jan 31, 2010
    If it has a vent pressure switch this would be the next thing to check since if this is not keeping the switch made then this could be the problem.
3 Suggested Answers
SOURCE: reddy heater won't stay on
Just go to Tate Heater repair shop for heaters and replace the Thermal Switch. The part number for the Switch is 113848-01. See if they have one if not they can order it for you. I just fix mine and it is now it purs like a kitten. Just the way the manufacture intended. I went also went down the road of buying a new thermocouple to find out that I did not need it. My advice change the less expencive Thermal Switch first in your part replacement list.
School of hard knocks
Posted on Oct 17, 2008
hardrocko
  • 1476 Answers
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
I have Jandy/Zodiac LRZE legacy heater and Jandy RS6 controller. When hooked up to RS6 and there is a call for pool heat the heater ignites but shuts off in about 30 seconds. When I disable the TSAT...
check your dip switches on the inside panel of the aqualink if you still cannot get it to work i would use the pool to 1 wire of a new wire you will run to the heater then 2nd wire to com then on the on the PCB board going to pins 1 and 2 of the big plug then turn heater all the way up when heater button is pushed or activated it will turn heater on and off
Aug 05, 2013 | Jandy Legacy LRZ Heater
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Rheem tankless shuts down on it's own.
Check to make sure wire is solid copper thermostat wire and not stranded
Aug 15, 2009 | Rheem Tankless Hot Water Heater...
Patton POH2520-U heater not working
I have a RD125T heater. At first it would run for a while and shut down. Turn it off and back on it would do the same. Now when it is turned on it acts as if the switch was being turn off and on. Sometimes the heater will fire for a second then shuts down. Most of the time it just shuts down, Forest
Jan 30, 2009 | Patton POH2520-U Oil Filled Radiator...
Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Oct 02, 2008 | Lasko 5132 Ceramic Compact Heater
Back light will not come back on.
if your on the back light settings, then press the down arrow three times. if your not, you can tilt it in a certain way so that you can kinda see what your doing
Feb 17, 2008 | Motorola Mobility TracFone® V170 Cellular...
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
