Question about Gateway Audio Players & Recorders
Computer just beeps when turned on but does not show on monitor monitor is ok
  • 1,675 Answers
Depending on how many beeps will determin what is wrong, the speed of the beeps also, here is a link that might help
http://www.pchell.com/hardware/beepcodes.shtml
Posted on Jan 30, 2010
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Dell e771p monitor cant turn on. Noise beeping sound from monitor
The monitor is not worth fixing and I recommend replacement. The good news is that you've confirmed the problem is not with the computer!
Sep 16, 2009 | Dell E771p 17" CRT Monitor
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Monitor Shows pixelated colors then flashes no input and turnsoff
If it is a desktop, try another monitor and see if you're gonna get the same problem. If its a laptop, connect an external monitor to it. If the other monitor shows the same thing, it means to say that there's just something wrong with your video card. If that's the case, you might as well uninstall and reinstall the video driver. If in the other case, the other monitor's fine then definitely its your monitor. if there's a reset button or a factory reset button available on your monitor then reset it. If the same thing happens, get it replaced.
May 06, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
No signal shows on monitor
When a computer beeps on start up there is a crucial input output piece of hardware no working. If you have any experience with computers check to make sure everything is conected right. I inclued a link for support for your computer. Larry
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390&LINKTEXT=Support%20Solutions
Mar 06, 2009 | Computers & Internet
Well the fact that your computer beeped tells me that there was a fault in either the motherboard or the video card. I would first replace the video card.
Dec 17, 2008 | Dell Dimension 9200 PC Desktop
Monitor beeps when turned on no picture
disconnect signal cable if monitor show massage no signal check signal cable then monitor is ok then open cpu check whether dust is in ram then clean the dust and again fit the ram the problem will be solved if not then disconnect ram listen beep and if contineus beep comes then motherboard is ok if no beep then motherboard is faulty replace it
Nov 26, 2008 | NetTV DTV 34XR 34" CRT Monitor
MicroATX motherboard work but the monitor shows a black screen.
I assume the monitor is turned on? Try the monitor with a known good computer to verify it's OK. I believe this board has AGP video. Verify that it's properly seated, or try another board.
Sep 13, 2007 | AMD Asus A7V-ML Socket A MicroATX...
115 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
