Question about Mitsubishi WD-62525 62" Rear Projection HDTV
How do we solve this green blinking light on our Mitsubishi 62725? My husband is an Electrical Engineer and has taken it apart and replaced the capacitors. The green light is still flashing. We're frustrated. Can someone help?
  • 9 more comments
  • mcameron22 Jan 30, 2010
    when I hold in the device and menu buttons together for 5 seconds nothing happens. The green light of death continues to flash
  • mcameron22 Jan 31, 2010
    I see one more cap on the power board that looks swollen...could this be part of the problem
    I dont have the full service manual, all I have is the chassis part replacement instructions. Where should I check the supply voltage and what should I expect to see
    What should the voltage be at the standby power output and where is it exactly
    I am not getting any voltage readings at any of fuses mentioned in the diagram. the fuses that are not mentioned have some voltages (F9A08 = 12 VDC). I went ahead and replaced the one swollen cap on the power board (C9A62) and I am still getting the timer light and still no response when I try to check the error code. What is my next course of action
    Is there any way to just bypass the timer?
    I just double checked my voltage readings and D9A50 and D9A51 are marked as D9A60 and D9A61 on my board. I am getting -/+ 17 VDC on the diodes. does the 2V difference matter? Most importantly I am not getting the 3.3V on pins 6 and 8 of the PA (I am getting about a half a volt on pins 1 and 2 but nothing any where else on the PA connector.
    Are you still with me?
    Im not sure if Welcomjee is still with me or not and I am still haveing problems with the flashing green light of death
    I had 2 swollen caps on the FMT board. I replaced all four of them. I also replaced all four caps on the DM board. This did not fix the problem. That is when welcomejee suggested that it may be the power board. I only had one new cap left so I replaced the only one on the power board that looked swollen. Still getting the timer light. Is there anything that I can check to figure out which board is giving me the problem? ( I am pretty sure that I have the card reader unplugged also, that is the usb and ieee 1394 plugs on the outside of the DM board right?)
    I remember seeing the E2P board that you are talking about. I will have to break the chassis back down to get to it. I think that it was on the DM board. In the mean time what can you tell me about the chassis replacement program that Mitsubishi has...how do I get one and what is involved with installing it
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
First : if you just replaced 1 cap it is a good idea to replace all four; and if the green light does not stop blinking (it is the FMT booting up) you will not get the 3.3 volts.
Some information for you that you may or may not know: all these sets are failing with three primary boards--the power supply board, the FMT board, and the DM board.
It has gotten so bad that about 2 months ago Mitsubhishi began a chassis replacement program---entire replacement chassis that wholesales for about 200.
If you have the assembly instructions you can see where the other two boards are---the problem with these sets is if repairing the power board fixes it, there are dozens of surface mounted caps on the other two boards mentioned that also start to fail, fix one board and a few months later one of the other two go.
I presume you also followed the instructions to unplug the card reader located at the front of most of these sets as it can (not often) cause this problem.
You may also want to at that time unplug the keyboard and set if the set will turn on--once in a while the actual reset button will be bad--seen three of them.
Considering how much time is involved to get this set apart if it was not the caps etc on the power board I would at least look into the chassis replacement----these sets were not one of Mitsubishi's finer design ideas.
Let me know if you have questions.
SD TECH
Posted on Jan 31, 2010
  • SD Tech
    SD Tech Jan 31, 2010
    FIRST: If you found bad caps on more than one board very low chance you are going to fix it--I went thru dozens of these sets with this problem---Mitsubishi would (these sets had this problem from day one) say "change this board" and then if it did not fix it change another and another--at some point they would have wasted hours of our time and just send a chassis to get it out of the way.
    As I am sure you know---caps can look perfect and be open-----I do not expect anyone can point to a specific part here that will cure your problem----the fact you have bad caps on more than one board points to maybe more than one is now damaged/bad.
    One other faint thing that may or may not help-----Did you see the E2P board? The tiny board that plugs into a large board its either on FMT or DM. The set uses the 2 eproms on that board--if you remove it and the set comes on(it will look very bad) it is bad.
    I am old school repairman----repair to board level but these newer sets sometimes are just not practical to repair in this way. Replace all four caps on power board and check any pico fuses near them. If that is no help consider a chassis replacement.
    SD TECH
  • SD Tech
    Contact Mitsubishi---I think the program requires you to go through an authorized dealer. I was in the shop two months ago where I used to work and they had 3 of these sets lined up and were replacing entire chassis in each.
    SD TECH
  • 10,594 Answers
Flashing green light shows TV got some problem, thats it.
Now in what section/ circuit it got problem, there is procedure to read out error code and check it in error code list to check listed sections.
All this info are available in service manual including part number list, schematics, exploded views info, that can be downloaded from HERE for small fee.
Below is procedure, how to activate error code operational check...
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
Now you have error code, check it in list...
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Hope this info will help you.
Thanks.
Posted on Jan 30, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jan 30, 2010
    OK, That means standby power supply is suspected, please check standby output voltage as mentioned in service manual.
    In my opinion, system control chip is not getting proper voltage to boot up properly.
    Thanks.
    Shahid Electronics Jan 31, 2010
    Full service manual is not even exist for this TV because circuit boards are not supposed to be repaired on component level.
    Yes, swollen capacitors can cause of this problem, power supply section is mentioned in service manual, need to test/ check carefully.
    Thanks.
    2 images taken from service manual are appended below that shows power board location in tv (top view) and standby power circuit for its output volts.
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi Capacitor Problem
hello where are you located if your in england try a place called wiltsgrove in birmingham 01217722733 or try ebay good luck
regards
shaun
Mar 31, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Tv will not turn on
when the green blinking light won't stop you have a bad dm module, it's about $800 just for the part. you could take it apart and try changing the big 1000 micrfarad at 16v capacitors on the dm board, but this almost never works on dlp's, and taking this tv apart to fix it is a major job, you need alot of money and a tv repairman to fix this.
Sep 15, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
Jul 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much.  My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed.  I sure think Mitsubishi should be held more responsible than they seem to be.  Some one suggested a class action lawsuit.  I would sure join one.  Jack P
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
