Question about Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet....
Need to increase the water temperature moen 270/3371
Need to change the preset 105 temperature on a moen 270/3371 so water is hotter. how do you do this?
  • 129 Answers
Remove handle, now you should see two white plastic pieces one slid inside the other. The inside piece should look like a gear. If you slide it out and rotate to the left a couple of teeth this will allow for handle to advance farther and in turn give you hotter water.
Posted on Jan 31, 2010
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
How do I adjust the faucet to get the water hotter?
If you have a hot water heater there's where you turn you heat up for your water if its hot oil its on the furnace boiler
Mar 05, 2013 | Plumbing
Can driving my buick without the thermostat hurt
Yes it can. The car will not get up to operating temperature as fast. It's never good to modify a car from its original factory specifications.
Jul 31, 2010 | 1992 Buick Century
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
& Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
May 17, 2010 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Does the atwood electronic Rv water heater have a temperature setting? Brad
NO. ITS FACTORY PRESET. YOU CAN INSTALL ANOTHER HOTTER T-STAT OR BUY A KIT THAT YOU CAN INSTALL TO ADJUST THE TEMP.
Oct 18, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Temperature setting is wrong. Stove is about 80 deggrees cooler than what the knob is set at. I am a yooper too.
If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.html
Hope this will help you
Thank you
Oct 02, 2009 | Hotpoint RGB745 Gas Kitchen Range
Intermatic electric water heater timer only gives enough hot water for a 7 minute shower. How do I increase this time?
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
May 14, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet.... Logo
714 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
