Question about Yamaha CDRHD1500 CD Player
When I power up FIRM.UPDATE message appears. In the past I could turn the power off and on a few times and the unit would work correctly. Recently though the unit will only display message FIRM.UPDATE and will not play a CD or the HDD.
  • tndwalmsley Jan 30, 2010
    How does the firmware get corrupted with just normal use? Why would I need to update software at any time? This unit has never been abused or messed with at all.
  • 542 Answers
This indicates the firmware was curropted or needs to be upgraded. Update the same with the help of expert engineer/service center experts.
Revert back for more assistance.
Posted on Jan 30, 2010
  • Rajesh Pai
    Rajesh Pai Jan 30, 2010
    We can't exactly tell how the firmware got curropted or upgrade needed as electronic items are very sensitive.
Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Feb 27, 2013 | Craig CMP741d Tablet
When I turn on my camera it shows green mode and turn off. If I turn on togheter yhe green mode button, appears the mensage " VER 0628A SBM FIRM" and it Freezer.
its look as you need to update your firmware
in your cam/and the message you see its your firmware version # you got to go on pentax web site under customer support and find it and downloaded to your cam,use a usb memory stick its work better
be carrefull to dowwnload the good version
[ VER 0628A SBM FIRM ] Hope thts gone help ask a friend
Mar 02, 2010 | Pentax Optio M20 Digital Camera
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
My Parrot Ck3200 Ls has worked fine for the past few months but it recently has frozen with the message "shutting down" displayed on screen. The unit does not power down, even when the engine in the car is...
You will need to disconnect power from the main control box. this will reset the unit. you will need to check the power is wired correct as incorrect power will cause this fault. best take it to an engineer.
Sep 30, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Failure to initialize after a microsoft update was installed
Go into the control panel and find the device manager. Then locate the UPS unit and right click and update driver. Then pick roll-back driver. This should install the prevous driver that was working properly. Then when you do windows update make sure to set it to hide that update so you don't re-install it again.
Sep 26, 2009 | Cybernet Systems CyberPower CP1200AVR...
Sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Feb 28, 2009 | Sharp AR-M205 Copier
"loading" message appears several minutes, then "no disc" message
check another disk.
or your dvd lens is weak to read dvd
i think it can read cds now.
if not, try to update firm ware or your dvd.
Jan 17, 2009 | Televison & Video
Son interrupted a firm ware update now PSP won't turn on
my investigations suggest that your son has "bricked" the PSP. Basically the memory that stores the firmware is corrupt and apparently only a main board replacement will fix the issue.
A google search found THIS. I have no affiliation with them and have never used them though.. might be worth a call at least??
Jul 02, 2008 | Sony PlayStation Portable (PSP) Console
Won't turn on after first time
saw this on a different forum.....I got one for xmass.....hope it doesn't happen to me!!!!!!!!
I apologize for the inconvenience. After further research with our engineers, a problem has been discovered on your C550. A file has been created to stop the unit from turning off and locking up. Please download the new file from your computer to the unit. The file is attached to this email along with instructions on how to get the file into the unit.
The following procedure will update the software in your C550 series and correct the power issue you are experiencing with your Garmin C550 series
1.) Let the Garmin sit without power for at least 24-48 hours.
2.) Plug the C5xx series into the your computer (using a USB port in the back of the computer) with the cable provided with the unit.
3.) After removing the faceplate on the front of the Garmin press and release the reset button. At this time the C550 series will reset and power on.
4.) Save the attached file included in e-mail from Garmin Product Support. Save this file to the desk top on your computer. Note: This will make it easy to find.
5.) Open the My Computer window (by accessing the start menu on the bottom left of your computer screen).
6.) Locate and open the Garmin Mass Storage device.
7.) Locate the Garmin folder and open.
8.) Open the remoteSW folder.
9.) Copy the file that you have saved to the desktop and paste it into the remoteSW folder you have just opened. Make sure that none of the files contained within the remoteSW folder is highlighted, or you will not be able to save the new file.
10.) A message window will pop up asking you to confirm that you want to replace the file; Select Yes.
11.) Disconnect the C550 series from the USB cable and let the unit restart. A message will appear on the screen stating "Updating PLD Software".
Note: the screen will fade out and go blank during this process. Do not be alarmed, this is part of the update procedure, and the screen will return to normal within seconds.
Dec 26, 2007 | Garmin StreetPilot c550 GPS Receiver
Yamaha CDRHD1500 CD Player Logo
24 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
