Question about Olevia LT37HVS 37 in. LCD HDTV
I purchased the Lt37Hvs on Aug31,2006. The DVD player and the TV have always been connected by an HDMI cable. Last night the HDMI stopped working. I pulled the connectors on each end to clean and re-insert. What I get is a black screen with a little white fuzz and every few seconds a crackly popping sound. I plugged in the S-Vidio cable and that didn't work. Finaly when I connected with the component cables the TV had sound and picture. Any suggestions. Thank you Tim
  • Olevia Master
  • 12,061 Answers
Check to see if the DVD has a setting to change it's Output... ie: Can you select, HDMI, RCA, Component? via the DVD? If so then reselect the correct one, perhaps Component is the "Default" output?
Posted on Jan 30, 2010
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
I keep a no connection between DVD player & TV
what is your input connection from DVD player to t v hdmi or avi etc .
Mar 17, 2015 | Pioneer DV-220V-K DVD Player
How do i connect dvd to tv?
there are usually two or three connections used by modern players, HDMI (http://www.pctechnologiesusa.com/catalog/images/COUHDMIFF.jpg) component(http://supply2build.com/uploads/categories/Component-Video.jpg) and composite (the yellow video in last link) you connect the device to your tv with a compatible cable between the two and change the tv to the proper input. The tv will usually have labels on the back to tell you which input is being used. If you have an audio amplifier then you must refer to your manual to figure out the proper pass though.
Aug 15, 2014 | Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
I have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HDMi Slot has stopped working
Your TV settings are they set to the HDMI port you are trying to use?
Dec 13, 2017 | Bose Lifestyle 28 System
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Olevia LT37HVS 37 in. LCD HDTV Logo
108 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
