It only scans in grayscale and b/w NOT COLOR - Office Equipment & Supplies
  • 12,061 Answers
You will in all likelihood have to check a box, somewhere that allows you to scan in color, look for it in the setup.
Posted on Jan 30, 2010
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Will Only Scan Color and single sided
Once I had a similar problem with CapturePerfect 2.0. No amount of setting will change the scan output. I hit the default option and then changed to the setting I wanted. It worked. May be there is a bug in the Scanning software.
S. Mohan, India
Jan 09, 2014 | Canon DR-3080CII Path-Through Flatbed...
My laser mfp 1815dn is reducing the size of the image of the document i am scanning. how do i get it back to scan and save a full page?
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
Documents:
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Dell Printers:Dell MFP Laser Printer...
How do I scan 35 mm slides on my C3180 all in one printer/scanner?
Scan specifications
? Image editor included
? Integrated OCR software automatically converts scanned text to editable text (if installed)
? Twain-compliant interface
? Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
? Color: 48-bit color, 8-bit grayscale (256 levels of gray)
? Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Aug 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Hi! My matchine is scaning all documents in Grayscale by def
yep!
sorry but our panasonic dp-8035 is only black&white document scanner.
Jan 14, 2010 | Panasonic DP-8035 Grayscale Copier
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Can't print in color
ummm...its a black and white copier/printer. the only thing it may do in color, is scan to your computer. if you just got it, you may want to browse through the owners manual because you're going to have to know how to change toner, drum, remove jams, etc.
good luck,
razors
Apr 13, 2009 | Brother Multi-Function Center MFC-8870DW...
Scan Snap - color/balck & white
You don't need to scan the doc again. If you have a graphics editing program (like Photoshop) you can change the mode to Grayscale and resave it. I bet you by now you probably have rescanned it anyway :)
Jul 28, 2008 | Fujitsu ScanSnap Manager
Scanning
is this still a current issue?
Jul 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
21 people viewed this question
jasbo
jasbo
