My big screen tv went off and reset it but you push the button and the power comes on and goes right back off
  • 2 more comments
  • chlndamst Mar 09, 2008
    push the power button and the tv comes on for about 2-5 seconds and the red standy by light is constanly flashing
  • chlndamst Mar 10, 2008
    I have a sonykp51ws500 when I push the power button it comes on for about 5 seconds and then shut right back off the stanby light flashes red 8 times and then there is a pause
  • fernando29a Oct 31, 2008
    I turn the the tv on after a few seconds it turns off by itself!!!
  • Larry  Dillon
    Larry Dillon May 11, 2010
    need more info. What brand, model and how old is the TV set. You way to general with your description.
    President:
  • 3,130 Answers
How many times does it flash?
Posted on Feb 19, 2008
When we push power button the green light flashes as if thinking about turning on and nothing happens, any way to fix this?
Posted on Feb 18, 2008
  • adixson Feb 18, 2008
    sony gran wega 60 inch 3 years old approx.
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
No power Mitsubishi Big Screen
Sounds like the power supply went bad. Repeated on/off pushing of the buttons causes the set to go into shut down. If a part is marginal this is when it'll go bad. Usually a bad power supply part and will need professional repair. Please rate!
Mar 26, 2009 | Mitsubishi WT-46805 46" Rear Projection...
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Lcd will not turn off
same tv similar issue
the menu screen is garbled and the buttons don't work
have to input the numbers on my radioshack remote pushing a 1 then a 3 etc
must unplug cord to reset logic board I was told
great clear picture!! lisa
Apr 29, 2008 | Gateway LCD26TV 26 in. Television
Model 60p8241 magnavox big screen tv
Your TV's power regulator may have a problem. But first check if your voltage is sufficient on the wall socket. Try using other electronic appliances there. =================================== Hope this helps let me know ok?
Sep 14, 2007 | Televison & Video
Televison & Video Logo
287 people viewed this question
Top Televison & Video Experts
