Either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
