Question about Dell Dimension B110 PC Desktop
My PC cannot "see" my CD/DVD drive at all. I have been totally unsuccessful in restoring drive. It has power. I replaced the drive and the ribbon cable...I have tried to edit registry per MS site, no luck at all. I tried to do a rollback but the drive is still not there. In the boot order it says to boot from CD second (CD drive not installed). I have done a system scan in device manager. Still no luck.
  • 1 more comment
  • azhockeyfan Jan 30, 2010
    Checked the connections and they all appear to be good. I can open/close the drive and it spools up but that's it. Any other ideas?
    I assume you mean to uninstall in the device manager, right? The device doesn't show there at all. Any other ideas?
    Thanks!!
  • azhockeyfan Jan 31, 2010
    No dice. It added the device "CD-ROM" in the device manager but it would not function or allow me to update/install the driver. I tried to do a restore to factory settings and that also failed.
    Thank you for the help...apparently this machine is beyond help.
    Scholar:
  • 185 Answers
Check for the loose connections,
probably the power connectiion to the drive .
Good luck.
Posted on Jan 30, 2010
    Scholar:
  • 114 Answers
Go to Control Panel/System and UNINSTALL THE CD/DVD.
Then reboot.
I have had this problem for some time, and was given this tip by an Acer Tech.
  • Rick Jan 31, 2010
    hhhhhhhhhhhhmmmmmmmmmmmmmmmmmmmmmmm.
    OK.
    Try this.
    Control Panel, and use the New Hardware Wizard. When it comes to what device, call it an OPTICAL or CD or whatever similar your system shows.
    Personally I avoid this but sometimes................
  • Rick Jan 31, 2010
    Interesting.
    I assume that the CD Drive works????
    Because if it doesn't then that is the problem.
    They fail for no apparent reason sometimes.
    Speaking of CD drives.... NEVER put in a disk that is cracked around the centre. I lost a BRAND NEW Drive because a CD blew up inside the drive. second time I used it.
How to restore from recovery disk after installing a new hard drive
The procedure to restore from recovery disk will vary according to which computer you have. Usually you insert the recovery disc in CD / DVD drive after selecting boot sequence 1 from CD/DVD in Bios. You then push the power on button. Once windows boots from recovery CD it will continue with building up the new hard drive.
Sep 03, 2014 | Computers & Internet
Easynote tj74
If you have a CD/DVD with the operating system on it, run that from your CD/DVD drive at start up. Do not attempt to try a windows restore from the computer hard drive. When the CD stops, you will have an option; Restore or Repair Option. Use that and try to fix the problem. If that fails, you will have lost what ever was on the hard drive and you must install Windows all over from anew.
Jan 06, 2014 | Computers & Internet
My computer says NTLDR is missing
The files necessary to boot Windows are corrupt or there has been a change to the drive configuration. To repair this you will need the installation CD or a windows ERD (emergency recovery disc) disc. If you can access the drive from a bootable disc try to perform a system restore from a recent restore point. If you use the install CD you can try the "repair" option and at the prompt type "fixboot". If unsuccessful retry and type "fixMBR". If unsuccessful you can try a repair install. The final option is a complete reinstall.
Apr 05, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My cd-rom is missing in my computer system
Hello, Please you will fit the sata/pata cable tightly in your cd/dvd RW
If it will face same problem install a new cable if you have spare cable.
Same as before
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
It could be a problem with the lens, you should try cleaningthe lens, it's already gone bad there is no harm in trying
If it doesn't work, you can either replace the lens or purchase a new DVD/CDdrive Hope it will help you Don't forget to vote me
Dec 24, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
DURING A VISTA SERVICE PAC UPDATE THE POWER WAS INTERRUPTED
try rebooting with a window boot cd or Vista cd...GL
Nov 21, 2009 | Computers & Internet
My gate way went down now it tell me no operating system found what do i do
Do you have a cd/dvd in the drive? (a non-system disk)
Try to boot into safe mode.
Try to restore to an earlier time.
If unsuccessful ... you may have to reload the operating system
Oct 21, 2009 | Computers & Internet
When i turn the pc on it goes to hit f1 to cont of f2 and then it says it can not read the hard drive
First open cpu cabinet.
Then reattach both connection cable power cable and sata or ide cable to harddrive.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios then check there your harddisk is detected?
If your harddisk is detected in bios you can boot your harddrive.
Let me know if you need more assistance.
Thanks.
Oct 06, 2009 | Dell Dimension 3000® Pentium® 4...
How do i install a gateway cd\dvd rom in my
There should be a lock/screw on the bottom of the PC that will realease the old unit. If you are unsuccessful a local PC shop can do it for around $25 and maybe while you wait.
Jul 26, 2009 | Computers & Internet
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Dell Dimension B110 PC Desktop Logo
95 people viewed this question
Alun Cox
