Question about Brother MFC-440CN InkJet Printer
Brother MFC-440CN USB Printer double prints letters
My Brother MFC-440CN USB Printer double prints letters. I tried the allignment utility several times but none of the options (1-8) are even close. What can I do to be able to print without the double letters?
  • Anonymous Mar 18, 2014
    canon mx452 is printing double line letters how can i fix this
  • 677 Answers
Did you use Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine.
When they see it’s Generic Cartridges, it will print lines thru the words, mis-align the letters & put stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
  • jonathanm_ol Apr 09, 2011
    My MFC-440cn likewise prints double letters when printing from word or browser; however, when I print from the alignment menu the instructions (same font & size) do not print with double letters.
    Any advice?
  • cns assoc
    cns assoc Apr 09, 2011
    I hope this info helps you. the link is below for alot of more helpful information from brother.
    http://welcome.solutions.brother.com/BSC...
    Setting the Alignment:
    Press the Ink or Ink Management key on the control panel.
    Press the up or down arrow key to choose Test Print and press OK.
    Press the up or down arrow key to choose Alignment and press OK.
    Press Black (Mono) or Color (Colour) start. The machine begins printing the Alignment Check Sheet.
    By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
    Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the up arrow key or 1 or "+" to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the down arrow key or "-" to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
    Press Stop/Exit.
    pls ratge me. and good luck.
    Thanks
Printer alignment
first clean using tools and then allign. GL
Aug 19, 2013 | Brother MFC-440CN InkJet Printer
When printing lines are running through the sentences.I have a brother mfc440cn printer
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
Black will not prtint. All the colors print fine on my Brother MFC 465CN. Have already: 1. Changed black ink cartridge 2. Reloaded printer driver Almost seems like some deeper issues where it...
GENERAL PRINTER TROUBLESHOOTING ADVISE:
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menu system or on the computer through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily works.
Nov 08, 2009 | Brother MFC-465CN InkJet Printer
Brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Sep 04, 2009 | Brother MultiFunction Center MFC-440CN...
My Brother MFC 440CN will not print
printer 440cn does not print. you call the printing option and the printer icon star jumping for a while then stop.I then open the printer queue and it is empty. I am running mac OS 10.58 in my Imac
Jun 20, 2009 | Brother MFC-440CN InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
I need to change to size of the print
You have to change the size within the computer software (word?). Use a 11 or 12 size and arial or times as a standard. The mfc prints the job as given by software (with settings given by user).
Nov 27, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN InkJet Printer Logo
756 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
