Top drawer not emptying fully
The drain hose on this machine appears to move with the sliding drawers, which can make it easy to break or clog. In all honesty, this model and company has a horrific track record, and because of that I would recommend - after taking simple troubleshooting steps like checking the drain hose for clogs and listening for the water pump - simply tossing it and obtaining a more reliable unit.
Here are solution posted by some fixya expert, hope it will give you a nice idea/solution concerning about your problem. Click the link from some expert.:
http://www.fixya.com/support/t215398-f1
thanks,
Hi again may i know if you replaced or you move the location of your machine, though it was still on the same place where you first use it.
I ask you this question cause maybe the position or the level of the machine may affect for not completely draining the water inside in result that not all water can go thriugh the drain hole/plug.
Hope to more from you.
Thanks,
-micro
Check inside the basin area for something clogging the drain opening first..
that's a good possibility. of course, this unit has worked prior, right?
I'm bailing on this solution, since it seems the EU has an agenda that means milking the well meaning experts here for almost free and unequivocable advice. SYonara, amigo.
nope..scroggins..you made it harder than 5 bucks worth of know how
I have cleaned filter and drain opening still does not empty fully
The dishwasher does not drain fully when it has completed its wash
The unit was working fine for a couple of years. Bottom drawer is still working okay.
Some solution telling me to replace machine. I want to fix the fault. try harder
My problem must be in the too hard basket.
Thank you for your continued comment, still trying to fix machine. The machine has not been moved since installation a couple of years ago.
scroggins
