Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Water in grounds container - Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
  • Jura Capresso Master
  • 1,711 Answers
The coffee solenoid valve return side is blocked from dry coffee. You can use cleaning tublets to clean some times the coffee group. With this it might be unblocked if not then you should remove it and clean it with warm water
Posted on Feb 13, 2010
I need to know an example of each part of the water cycle listed below: a. Evaporation b. Precipitation c. Runoff d. Condensation e. Transpiration
Hi Stan:
Evaporation - Hot sun shining on damp ground in morning. The moisture on the ground EVAPORATES as the ground dries.
Precipitation - Rain falling onto the ground is PRECIPITATION
RUNOFF - When rain falls onto the ground, some of it is absorbed into the ground. The portion that is NOT absorbed becomes RUNOFF in that it runs off the surface that it fell on.
CONDENSATION - Air contains water vapour, and the higher the temperature, the more water vapour it is capable of containing. This is expressed as relative humidity. When warm air that contains lots of water vapour is cooled, there will be a temperature reached where it cannot contain all of the water vapour that is present, so the excess water vapour CONDENSES on cooler surfaces. This process is called condensation.
If you Google TRANSPIRATION you will get a link to Wikipedia where you can read the definition. If you have problems with my explanations, you can also use Wikipedia to get the formal definitions.
Mar 13, 2015 | Washing Machines
Where is the ground coffee shoot?
Open the door and you will see four bins top right is the bean container - bottom right is the water container - bottom left is the waste container - top left is and empty storage bin - remove the top left bin and you will see a flap door - lift the door up and insert your ground coffee.
Jul 18, 2014 | Miele CVA 4066 Stainless Steel
DELONGHI PERFECTA SAYS INSERT GROUNDS CONTAINER WHEN IT'S ALREADY INSERTED
Just had the same problem after washing my ESAM5500.
Seems that some water hot on the switch that is triggered when grounds container is inserted.
My solution was removing the bottom panel (5 screws if I remember correctly) and disconnect the green wire from the switch (there are three wires - green, ping and blue). When the green wire is disconnected, coffee maker thinks that grouns container is inserted all the time - even if it is removed.
Jul 30, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Coffee grounds overflow
Tressia,
An overflow can occur when using certain brands of coffee that are finer ground or using a water softener, bottled water, reverse osmosis, or filtered water. If you will call Bunn Customer Service, you can get a flow restrictor sprayhead which will eliminate this issue.
May 08, 2010 | Bunn NHB Coffee Maker
How do you make coffee in cafetiere 6 cups
You grind the beans quite fine
Pull up the knob on the lid till it pulls out of the top and the filter out of the glass container.
Put enough of the the ground coffee for six cups into the glass container , pour on boiling water till it reaches about one inch from the top
Put the top back on a push the knob slightly down to locate it in the top of the glass container
Give the water a few minutes to work on the beans and then gently push the knob all the way down so that the filter goes to the bottom og the glass container taking the grounds with it
Pour the coffee
Enjoy!!
Jun 19, 2009 | La Cafetiere Santos SN030200 3-Cup Coffee...
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
267 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
