Question about Epson Office Equipment & Supplies
Epson Perfection 4180 scanner worked perfectly. Today I get merror message: "ScanToFile Application has encountered a problem and needs to close." Help.
  • 3,230 Answers
Well first of all you can try to uninstall the driver of your scanner and then reboot your computer after then install the driver of your scanner from the cd disk comes with your scanner, if further you have the same problem then please follow the below steps -
1. RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2. Select the HARDWARE tab, then the DEVICE MANAGER button.
3. Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or
OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4. Disconnect the USB cable and close all open windows.
5. Click on START, and CONTROL PANELS.
6. Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on
CHANGE/REMOVE.
7. Go to START, SEARCH, and ALL FILES AND FOLDERS. Select Advanced option
and ensure there is a checkmark next to SEARCH HIDDEN FILES and FOLDERS.
8. Search for files where all or part of the file named is OEM*.* and a word
or phrase in the file contains EPSON. Search location should be set to
C:\WINDOWS\INF or C:\WINNT\INF.
9. Delete all files that are found if this is your only Epson product. If
you have another Epson product, you will want to open each individual file
and determine which files pertain to your scanner, and then delete only
those.
10. Go to START, SEARCH, and ALL FILES AND FOLDERS. Search for files where
all or part of the file named twain.log . Search location should be set to
C:\. Please delete the twain.log file and repeat the process for
twain001.mtx, twunk001.mtx and twunk002.mtx. and epfb5 and escndv
Please post comments if further you have the same problem......
Good Luck!!
Thanks
Posted on Jan 30, 2010
Carriage won't move
Are you getting an error message on the computer? If not replace the scanner.
Apr 29, 2012 | Epson Perfection 4180 Photo Flatbed...
My Epson 4180 scanner will not turn on. I tested the power supply and it is O.K. Frank
Ascertain that the computer recognizes scanner connection. For example, once ascertained the device connections to circuits been attained, trace the connections to the computer also from where programs should recognize the new feature required. Usually scanners turn on from computer programs. Once click activated would power on scanner ready to capture picture graph displays.
Feb 27, 2011 | Epson Perfection 4180 Photo Flatbed...
I can not find a driver to work my Epson Perfection 4180 scanner with Mac OS x Snow Leopard 10.6.2 Tried to find Rosetta but can not find it.
The scanner driver is available from: http://esupport.epson-europe.com/FileDetails.aspx?lng=en-GB&data=kVFQIoh3k1l80PUnuqTagjyIvHOjkJY8mVM4d6wWJEgU003D&id=28205 Rosetta may not be required, if you have problems with installing and using this driver then a full uninstall may be required. If this is the case then let me know.
Jan 21, 2010 | Epson Perfection 4180 Photo Flatbed...
Epson perfection application not working on G5 10.5.8
hi there. you actually downloaded the right driver :
try this Run Photoshop in Rosetta mode; Epson Scan 2.77A only runs in Rosetta mode.
Follow the steps below to run Photoshop in Rosetta mode:
  1. Open the Hard Drive, select Applications > Adobe Photoshop, then select the Adobe Photoshop icon.
  2. Hold down the drv_mac_407_er.gif-I keys to open the Get Info window.
  3. Check the Open Using Rosetta option, then close the window.
  4. Start Photoshop.
Dec 23, 2009 | Epson Perfection 1250 Flatbed Scanner
Scanner has racheting noise and red light stays
This noise is caused by the transport lock. Power the scanner off. Lock and unlock the transport lock a few times and then leave it in the unlocked position again and power on.
Nov 20, 2009 | Epson Perfection 4180 Photo Flatbed...
Error message on attempt to scan: "Instruction at "0x673328c8" referenced memory at "0x21900668". The memory could not be "read"." need fix.
I must blush to say that I reviewed the error messages more closely and discovered that the solution was with an application, not the scanner. Thanks tremendously for your prompt attention.
Nov 17, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Perfection 4180 won't scan my negatives
cant scan film with epson perfection 4180. how can this be fixed?
Jun 10, 2009 | Epson Perfection 4180 Photo Flatbed...
I cannot open my scanner instead this appears:"escndv.exe has enc
try downloading and installing the copy utility v3.3. usually nost espon hardware need more than one driver to work properly. my printer needed 3 drivers...
Apr 16, 2009 | Epson Perfection 3590 Photo Flatbed...
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
