I need to replace the water valve in my 10 yr old Kenmore laundry center (stacked unit) washer. How do I get to the old water valve?
  • joe_mauro Jan 30, 2010
    Yes. The model number is 417.98702891. The serial number is XE01402015
    Thanks! The tub moves far enough to the left side that I can replace the water valve without removing the tub. I appreciate the advice!
  • 8,197 Answers
May I get the model # of the washer to help you.
Posted on Jan 30, 2010
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
The pump on my kenmore laundry center washer is not pumping the water out of the machine...any suggestions?
check power to pump during drain cycle with meter. if power is good then it is probrobly the pump as the culpret.
Aug 18, 2012 | Kenmore 88732 Top Load Stacked Washer /...
My stackable washer/dryer laundry center no longer allows adequate flow of hot water. It was fine one load, and hasn't worked since. Now it just trickles hot water into the washer. Any ideas?
If you have checked that the hot water tap is turned on fully and the hose is not kinked or squashed at the back, it is worth while checking the hot water inlet filter. Turn the tap off and remove the hot water hose at the washer end. Inside the inlet port there is normally a little filter which should just slide out. Clean if necessary and replace it and the hose. If after turning the tap back on there is no improvement, the problem is symptomatic of a malfunctioning hot water control valve. Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Apr 07, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water won't drain
Check filter or pump. Clean as required..
Oct 03, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Laundry center 41799570120
Could be the bearing. The water seal may be damaged, allowing water to get to the bearing. You should have the seal and bearing replaced.
Oct 28, 2007 | Kenmore 93702 Top Load Stacked Washer /...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
