Question about Toshiba 23HLV84 23 in. TV/DVD Combo
I HAVE A OLDER (2005) TOSHIBA MW24FP3 DVD/VCR/TV COMBO UNIT. THE DVD PLAYER IS STARTING TO RUN OUT OF GAS, SKIPPING, SHUTTLE PROBLEMS ETC. CAN IT ACCEPT AN EXTERNAL DVD PLAYER THROUGH THE FRONT CHASIS JACKS? I BOUGHT A SIMPLE DVD PLAYER THE OTHER DAY AND NOTHING IS HAPPENING. IS THRE SOME SORT OF SEQUENCE THAT NEEDS TO BE PROGRAMED INTO THE SET TO ACCEPT THE NEW PLAYER? VERY FRUSTRATING, INDEED.
  • Toshiba Master
  • 3,866 Answers
Absolutely you better bet it can, just hook up the cables to the front and select the input on your tv and you should be ok. For the internal DVD try running a cleaning disk you never know it could be just dirty.
Thanks if you like my advice and solutions please use the thumbs above to rate it and give me some feedback as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jan 30, 2010
I'm getting tired of trying to get the correct code so that a radioshack remove control will work with a toshiba tv/dvd/vcr combo, model MW24FP3...any ideas?
Than u must used the original remote,still have it,not.Try website like Remotes.com to buy an exact remote to the original remote.
Oct 22, 2010 | Toshiba W603 VCR
Toshiba TV/VCR/DVD combo (MW20F51) won't read/play dvds.
this a laser unit dirty or dead, needs to be cleaned with a laser cleaner kit or replace the laser unit
Feb 19, 2010 | Televison & Video
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Connect to auxillary dvd player
to connect a DVD player to your TV/VCR combo is :
DVD A/V output to TV/VCR Combo A/V INPUT In the back of TV , if TV doesnt have an auxilliary A/V input , then
the other solution is to get a RF Converter box that connects to where you connect the CABLE service .
thats it . hope this helps , please rate this solution , thanks AJ
Apr 30, 2008 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
RCA x-100 remote lost is this one all compatible?
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 04, 2007 | One For All URC-3021 Remote Control
DVD player keeps skipping and gets very blocky looking and then sometimes it just stops I tried cleaning both the lenses of the dvd player with dvd lens cleaner disc and cleaning the dvds nothing seems too...
It sounds like the problem is with the DVD's you've been playing. I've gotten those problems before, but not on every DVD. How many different ones did you try playing?
Jun 16, 2007 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Toshiba 23HLV84 23 in. TV/DVD Combo Logo
195 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
