Question about DCS PHFS Phoenix III Outdoor Patio Heater
Flame out on a DCS Patio Heater
After I ignite the patio heater it will run smoothly for a couple of minutes and then click and it will shut off. I can immediately relight the heater and it will run again smoothly and shut off in a matter of two minutes.
Thanks,
  • 111 Answers
Thermo-coupler (cheapest to fix) or valve
Posted on Jan 31, 2010
  • MARK BIALLAS
    MARK BIALLAS Aug 30, 2011
    The DCS is one of the better patio heaters. You're pilot is probably partially clogged. When a slight breeze blows it off of the thermocouple it will make a click sound and shut down. Clean the pilot assy and make sure your thermocouple is not loose in the valve. It's not very common for the electromagnet in the valve to go bad but it has happened.
My gas endless summer heater shuts the flame off abruptly after 5 minutes or so. why??
The first consumable part to fail on a gas patio heater is the thermcouple, these can last anywhere between 1 year to 6 years. When faulty it will cause the heater to shut off when turned on at pilot. Found this site very useful patio heater problem solving.
Nov 18, 2011 | Endless Summer 233010 Natural Gas...
Portable patio heater is a DCS Phoenix Professional Patio Heater Model PHF8-DWBZ-L. Burner ignites and operates for a few minutes. Then teh flame is reduced to a short yellow flame. Regulator is covered...
The regulator covered with frost is the problem. It freezes the gas and the gas line up. But, usually this only occurs when it has been exposed to subfreezing (in the teens) temperature for a long period of time. The quick fix, is to soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. Once it thaws, the gas will start flowing again and you can light the burner. Generally, once it's flowing and being used, it won't freeze up again, right a way. Most propane companies add ethanol to the propane in the winter, to help keep it from freezing in the lines and the regulator.
Hope this helped answer you question and provided, at least a quick fix solution.
Apr 21, 2011 | DCS PHFS Phoenix III Outdoor Patio Heater
Have lost the control turn knobs for the ignition and heat settings
Gas control knobs can be very specific to the patio heater. Best to go for a universal or adjustable control knob, these have a grub screw that can be tighten to get a good fit, found this specialist patio heater company very helpful.
Oct 01, 2010 | Endless Summer 233000 Open Flame Patio...
Can you telll me how many BTUs is has?
There is a UL plate on the heater it should strate the BTU's on it I did find this for you Berkeley Forge G-PH001PSS Open Flame Gas Patio Heater. Patio, Alimentation: Gas, Open Flame, 12000 BTU
Oct 12, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Themal coupling needs replacing
Heating and A/C shop or supply. Plumbing supply too
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
Heating & Cooling Logo
507 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
