Question about Maytag MSD2756G Side by Side Refrigerator
Fridge is look warm but running freezer remains frozen
  • 254 Answers
Check your evaparator fan motor if its not working it wont pass the air to the fridge.. its inside the freezer possibly might have to remove back wall inside
Posted on Jan 31, 2010
Gsc3pgxcfss warm fridge, freezer working fine
It could be the servo on the diverter door, but it's most likely to be the main control board. Sorry.
Mar 23, 2014 | GE Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Oct 27, 2012 | Amana ABB1927DE Bottom Freezer...
I have a KIC 2 door fridge freezer. The freezer works but not the fridge part. It was working till a few days ago. The evaporator was frozen so i switched it off to defrost it. Since then it doesnt co
Check that your evaporator fan is operating. If it is, then take the rear freezer shield off and blow warm air down the cooling tubes to defrost the tubes. One of more of your cooling tubes is frosted up.
Jan 23, 2012 | Refrigerators
Fridge is not cold and freezer is thawing all my frozen food , is compressor gone?
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
Nov 17, 2011 | GE Refrigerators
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Kitchen Aid Fridge
no ice in freezer section??? not able to keep meat frozen , is it making ice??? sounds like a compressor issuew and not covered by manufacture warr is generally not a worthwhile repair
Mar 02, 2008 | Frigidaire FRT21HS6D Top Freezer...
Maytag MSD2756G Side by Side Refrigerator Logo
125 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
