Question about Jenn-Air JGS8750 Gas Kitchen Range
Oven door how do i reinstall the oven door if i pulled it off while pulling the range from the wall
  • 49 Answers
It depends on the type of hinges, you would most likely have to push the hinges down and latch it with the small hook on both sides then put your door back on , push the door fully open ond unhook the small hooks.
Posted on Feb 18, 2008
How do I remove the floor panel of the oven?
typically toward the back wall,their will be 2 thumbscrews holding down the oven floor,remove those and pull the floor up and out from the rear. To reinstall slip the front lip of the floor into the groove in the front around the door first then push down and reinstall the thumb screws
Aug 06, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
How do I put the oven door back on, it was accidently pulled off and the manual does not show how to put it back on. We can't figure it out. The manual had only one small picture showing parts nothing...
We did fix our problem the the Thermadore. Someone accidentally pulled the door off trying to pull it out from the wall during a remodel at our church. We couldn't figure out how to get it back on but i found the info i was needing. It is now fixed but thank you for your time..
Jan 08, 2010 | Thermador PRG364GLUS Gas Kitchen Range
Kitchenaide KGST307 cracked inner oven window.
Open your oven door and look at the hinges. You should see a drop down thumb lock on each hinge that you pull down and after you do so, lift up on the door as to close. The door will catch on these thumb locks and then at this point continue to lift up on the door as you pull the door out at the bottom. Reverse directions to reinstall.
Apr 05, 2009 | KitchenAid KGST307 Gas Kitchen Range
My Maytag Electric Range oven part will not heat over 200* ......
Unplug the range.
Open the oven door.
Remove the racks.
Remove the 2 screws holding the bake element to the rear wall of the range.
Carefully pull the element from the access holes in the rear wall.
Remove the wires from the element.
With your meter set for continuity, put one lead on each element end.
If you get a reading it is good.
If it is good. Replace the wires and reinstall the element.
Pull the range out from the wall.
Remove the rear panels.
Plug the range back in.
Set your meter for 220volts or more.
Careful now because you are working with live voltage.
Set the oven for bake.
Put a lead on each element terminal to check voltage.
If you have 220 volts at the element, unplug the range and unplug the temperature sensor.
Set your meter for ohms.
Check the 2 leads on the temp sensor.
If at room temp the sensor is 1050 - 1100 it is OK. If not replace it.
If the temp sensor checks out OK, replace the ERC
Mar 12, 2009 | Maytag MGR5880BDS Gas Kitchen Range
The oven door locked and won't open, please help
Push and hold the cancel/off button for 4 seconds.
See if a code appears. If so write it down.
Turn off the gas supply to the range.
Unplug the range.
Remove the top and bottom rear panel covers.
On the left side just below the rear burner is the latching mechanism.
Unhook the actuator rod from the mechanism and open your oven.
Do you have a code to report?
Mar 09, 2009 | Whirlpool GS460 Gas Kitchen Range
How to install Maytag oven door for model MGR5765QDQ ?
Pull the door mount bars to the first stop--where you keep the door open to broil. Slide the door back down on the bars.
Mar 02, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Reinstalling oven door
be exstreamly careful do not put your fingers near the hinge. somehow pull the hinge apart till the stay open and you may see a hole in it, put somethjing like a nail into it to prevent it from snapping closed. then put it into the slots on the oven till they are in the right position then open the door all the way and then just pull out the nails. That is if it is that type of hinge.
Oct 30, 2008 | Roper FEP320 Electric Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Oven Door
did it lift off in upward pulling>?
Jan 01, 2008 | Whirlpool GS475LEKS Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
134 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
