Question about Zanussi F1045W Front Load Washer
Machine not emptying or spinning. Have unscrewed pump cover and instructions then say remove anything from pump impeller how do you get into this once the pump cover is off?
  • 1 more comment
  • bluezzr1200 Jan 31, 2010
    What is a shop vac?. does this mean we have to take off the back or top off the machine.
    Many thanks for your help.
  • bluezzr1200 Feb 01, 2010
    Yes, we will try this
    Thank you for your help.
  • Zanussi Master
  • 3,051 Answers
Hello there: Please check out the solutions that i have provided below and please don't forget to rate the solutions I have provided for you Best regards Mike It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Feb 01, 2010
  • Michael Thomas
    Michael Thomas Feb 02, 2010
    Hello there:
    the shop vac is used to get all ofthe water out of the machine if you have the cover off the pump you should be able to see inside of the pump now if thereis any thing that is in the pump like material or dirt or any thing that will clog it up remove it alos if you can remove the lines gong to and from the pump and clent them out as well ok then if every thing looks good reassemple and plug in the machine and retry it ok please keep me posted on how this is going
    best regards mike
  • 15,935 Answers
You cannot access the impellor from the outside - it is sealed within the housing. Remove the hoses (and have a shop vac handy) to access the impellor to see if there is debris preventing it from spinning.
Thanks
Posted on Jan 30, 2010
How to remove impeller from a.o. smith
the impeller is screwed on like a bottle cap. On a sq flange motor, it is harder to do. the armature spins when you try to remove the impeller. you can try to use needle nose vise grips to keep it from spinning by gripping the shaft from underneath (between pump and motor) then try unscrewing the impeller. If this does not work, You will have to remove the armature. their are 4 thru bolts that can be removed from the back of the motor. they are each about a foot long. WD40 the place where the connect to the pump housing or you may break the housing. When removed, you can tap the rear of the armature with a hammer and chisel. when it pops free, remove the armature from the motor. you now have in your hand, the pump still attached to the armature. you can place the armature in a vise, (make sure you do not damage it) then use channel lock pliers to unscrew the impeller. The impeller may still break. Or you can try and place a wedge in the pump housing to keep the impeller from moving and turn the armature. good luck, it is not an easy job.
Nov 10, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
The water is not out
The pump should be inspected if •
the machine does not empty and/or spin •
the machine makes an unusual noise during draining due to objects such as safety pins, coins etc. blocking the pump. Proceed as follows: •
Disconnect the appliance. •
If necessary wait until the water has cooled down. •
Open the pump door.
Place a container close to the pump to collect any spillage. •
Pull out the emergency emptying hose, place it in the container and remove its cap. •
When no more water comes out, unscrew the pump cover and remove it.
Always keep a rag nearby to dry up spillage of water when removing the cover.
Remove any objects from the pump impeller by rotating it.
Put the cap back on the emergency emptying hose and place the latter back in its seat.
Screw the pump cover fully in. •
Close the pump door.
Oct 21, 2012 | Zanussi ZWF1020 Front Load Washer
My dishwasher won't empty
This condition is commonly caused by:
- Drain pump jammed
When you wash your clothes, any small objects (e.g. hair pins, coins etc) are flushed down the drain pipe but often get jammed in the drain pumps impellar (this is the tiny propeller on the pump).
Firstly, place a bucket on the floor....then lower your drain hose (from your tub) into the bucket - the gravity will naturally drain the water into the bucket. Be careful to raise the hose and empty the bucket each time, until the machine is empty. Remove any wet clothes from machine (you will need the bowl to be emptied).
Once empty, you can now check the drain pump.
Turn the machin off at the power.
Locate the drain pump cover (usually near the drain hose, on the back or side). Place a large towel on the floor beneath the pump cover (as remaining water will escape onto the floor). Unscrew the drain pump cover and allow the water to drain (if your pump cover contains a filter, then clean everything from this filter).
Then, look inside the drain pump cavity for anything obstructing the little propeller (remove any objects). Insert your finger inside the cavity and rotate the little propeller - you should feel a resistance, similar to a rubber band.
Re-install the drain pump cover (or filter) and ensure it is sealed properly. Turn ON at the wall.
Fill your bucket with water (from tub) and pour into your machine.
Turn machine ON, and select the last SPIN (or drain) cycle and check if machine now drains correctly. If ok, then problem now solved and you can put the clothes back into the machine for a final rinse/spin.
If machine still not draining after inspecting the drain pump, then you may have a suspected faulty drain pump - a technician can run a diagnostic process on your machine's control pad to find the diagnostic codes.
Please do let me know, if the above process helps you solve this.
Cheers,
Oct 02, 2011 | Dishwashers
Hi there i am using lg wf-f712pc a top load washing machine and today i realised that the water did not drained out and the machine refused to spin after washing.... when i forcefully tried to turn the...
Your machine won't spin because it can't drain.
You probably have a blocked drain hose or a faulty/blocked pump.
If you put the drain hose below the water level in the machine it may run by gravity. If it does flow this way it would show that the hose is not blocked (completely).
Make sure the machine is empty before continuing.
NOTE! Unplug machine from power supply!!
There is probably a small cover near where the drain comes out of the machine. Unscrew this cover and you will expose the pump filter, which may be (partially) blocked. Check for coins or similar which may be jamming the impeller blades..
NOTE! Any water in the machine will flow from here!!
TIP! Lean the machine forward to help contain the last of the water in the tub.
If the drain hose is clear and the pump is still not draining the machine you may have a failed pump motor.
Pump motor replacement is not a big job for an experienced tech.
Good luck....Nomess
Oct 06, 2010 | Washing Machines
Tryiing to replace motor cannot get diffuser and seal plate free how do they come apart
First remove bolts holding motor to wet end. Pull motor back and out of wet end. Diffuser should just fall off. Not held by anything, there are just some locating tabs. Next, unscrew impeller. Some impellers may have a screw holding it on to center shaft. If so, unscrew.(Backwards thread). Remove back cover on motor and hold centershaft with large screwdriver or wrench on flat of shaft. Unscrew impeller. Next, unscrew 4 bolts holding motor to seal plate.
Apr 17, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Jun 04, 2009 | Bosch Washing Machines
Kenmore Elite HE4T not spinning and draining
The only way to access the imperller is remove the coin tray (unscrews and pulls out) and the hole into the pump on the right side will have the impeller right there..The pump itself shouldn't be taken apart. It may not seal up correctly.
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Bosch washing machine spin cycle is not working
I don't know if this will solve everyone's problem but I found the problem in my machine. I found a SHOUT color catcher stuck in the impeller of the drain pump in the bottom of the machine. If you remove the round face plate covering the drain plug and then unscrew the drain cover you can access the little pump impeller. I found the 5" x 10" color catch sheet stuck and impeding the rotation of the impeller. Once I removed it, reset the machine, reinstalled the drain cover and outer cover and restarted the machine, it worked fine.
We use alot of these color catchers and have never had this problem before. But as they say, there is a first for everything.
Steps to repair:
  1. Unplug the machine
  2. Lift an edge of the round face plate covering the drain on the lower right corner of the face of the machine. Then rotate it clockwise about 1/8 of a turn. Remove the face plate.
  3. If you are sure your machine is empty you can simply unscrew the drain plug which is a roughly 4" round plug with a handle molded into it. I had standing water in my machine so I vacuumed out the water first then held the vacuum at the opening of the drain plug and slowly unscrewed the plug letting the water get sucked up . This took about 5 minutes just to drain this drain trap.
  4. Unscrew the drain plug (if you haven't done it already)
  5. You have to fully unscrew the drain plug then pull on the plug a bit to get it to come out.
  6. Examine and remove any debris you find in the drain trap. (In my case, this where I found the color catcher stuck up in the impeller of the pump which is toward the middle at the bottom of the drain.)
  7. Reinstall and snug the Drain plug. To do this you need to properly orient the plug to get it to go in correctly. You have to wiggle it alittle as well.
  8. MAKE SURE THE PLUG IS SNUG OR IT WILL LEAK!
  9. Double-check the security of the plug
  10. Reinstall the face plate by orienting the tabs on the cover and rotate in place counter-clockwise.
I hope this helps some of you out there.
Sep 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
WASHING MACHINE FRONT LOADER
If it's similiar to the F1231 w than i found a color catcher caught between the pump impeller and pump cover. this is located at the bottom right front of the 1235W and flips open. grey hose beside it pulls out and remove cap of hose and drain into bowl.
Tip take wet clothes out of machine to speed up the emptying of machine - this dawnwd on me after a few minutes.
Some more water will come out when you remove the pump cover - screw anti clock wise.
ee pages 18-19 of the zanussi guide for cleaning instructions. I found this link to manual on internet
http://www.manualshark.org/manualshark/files/6/pdf_13638.pdf
or check your own manual for cleaning instructions and remember unplug power first - just in case. you may need to reset your wash to do a rinse again as i got a vibrating sound when i restarted and skipped to spin. hope this helps
Dec 31, 2007 | Zanussi Washing Machines
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
Zanussi F1045W Front Load Washer Logo
127 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
