Question about Fuji FinePix S3000 Digital Camera
By mistake I used power cord from DVD player to charge my camera. And camera doesn't work any more. It completely die.
  • 3,866 Answers
You might have burned it out, I cannot tell I would suggest you take it to a tech locally. The issue with plugging a wrong adaptor in is voltage this will pop the supply inside the camera.
Again from here I cannot see but if it does not turn on yes its damaged.
Thanks and please lay in your ratings.
Posted on Jan 30, 2010
Cd payer will not play
Make sure it's plugged into an electrical outlet that works. Is the power cord removable? If so, then make sure it is inserted completely. Again of it is removable, then you might have accidentally gotten the DVD player's power cord mixed up with another removable power cord from something else. Sometimes, the power cord will have the DVD player's name on it.
Nov 17, 2012 | Televison & Video
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My Mintek portable DVD player's battery will not charge. I have rarely used the battery so I can't believe the battery is dead. The AC cord works to power it when plugged in. Why won't it...
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage. If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it. hope this helps.
Jul 26, 2011 | Mintek MDP-1880 8.5 in. Portable DVD...
The battery died. Can I purchase a new one can I use my portable dvd player without a battery?
hello,
you can purchase a new battery from an electronic shop close to you.
try to charge the battery for a while, then test it if it will work without being plugged to a power supply.
you can also use you audiovox PV33116 player without the battery, but you should take note that as soon as the power supply goes off, the player goes off too.
so it is advisable for you to get a new battery.
take care.
Jun 01, 2010 | Audiovox PVS33116 Player
Battery won't charge
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
Fuji FinePix S3000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
