Question about Gaggia Classic Espresso Machine
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4 cycles(wait for the light to turn off then stop till light comes on again before open steam valve)Frustrating as you get a watery coffee!!!
    President:
  • 1,618 Answers
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Posted on Jan 31, 2010
Overheating problem
i would take a close look at the water pump
if the water isnt moving through the system it basically becomes a kettle
thats why steam comes out of the bleed nipple
Dec 09, 2016 | Cars & Trucks
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Boiler not cutting out
hi thermosat or the water valve is staying open allowing the gas to flow at full rate when water is off hence the steam , boiler is very broken call a gas fitter to fix it .
May 06, 2010 | Heating & Cooling
Steam function SAECO Vienna Exclusive not works
Check the thermostat on the steam boiler, that could have tripped, or the element on there could be damaged.
Jan 23, 2010 | Saeco Vienna De Luxe Espresso Machine
My steam/hot water arm fell out along with no steam
Easiest way to get to it, remove the 2 screws in the bean hopper, and remove the hopper, there are a few screws under the water tank, this should give you access to the machine top. Check the end of the steam wand it might be blocked use a paper clip to clear it out. Run it under the faucet to make suree it is clear. Check the microswitch that is connected to the steam valve, It can be seen when you turn the knob to open the steam/hot water valve, make sure it is not stuck in the on position.
Dec 06, 2009 | Saeco Vienna Espresso Machine
The steam / hot water function on my saeco Vspresso does not work. It has intermittently worked in the 10 months I've had the machine, but I can't descale without this function. any ideas? I turn it on...
First check to make sure that the end of the steam spout is not blocked, use a paperclip. If you machine has a parnello on the wand check to make sure that the holes on that are not blocked also. If those are clear, then when running the hot water cycle push in knob if that works the the tap rod assembly on the steam valve needs to be replaced.
Oct 09, 2009 | Saeco Vienna De Luxe Espresso Machine
The steam function has stopped working, I regularly descale, but it just stopped working all of a sudden. Any ideas how to fix it?
Try this, using a paper clip make sure that the end of the wand is not clogged. If not then open steam wand and then push the knob in, if that works then the valve stem needs to be replaced, if it doesn't, can you get hot water from the valve, if yes then the thermostat or the element on the steam booster boiler is damaged.
Sep 10, 2009 | Gaggia Titanium Espresso Machine
Bodum granos new will not function
the connections to the heating coil element looks faulty.check it.
Jan 18, 2009 | Bodum Granos 3020-16 Espresso Machine
Gaggia Classic Espresso Machine Logo
110 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
