Question about Panasonic Lumix DMC-LZ8K Digital Camera
The lens is jammed and it won't go back in when i turn it off. HELP!
  • 668 Answers
Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.If this did not work then.
The helical threads inside the camera probably got bent to the point that it won't work anymore.
You need to get repaired .
Hope this helps.
Posted on Jan 30, 2010
Sony dsc-w190 won't turn on
The system control board has shut the camera down to prevent damage, the lens housing will need to be replaced because you have two problems, one the lens is jammed and second the shutter is open, the cost to repair will be equal if not more than a new one.
Mar 31, 2012 | Sony Cyber-shot DSC-W190 Digital Camera
DSC W55
Take battery out await two mintes and put battery back in, this should reset the camera.
regards
Mar 25, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lumix digital camera lens won't open all the way. I live in Orange county Califonia. Please give me a place to get it repaired it might be the battery charger. Help need telephone number...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sep 16, 2011 | Cameras
FinePix F480. Zoom keeps coming out at an angle and jamming so that it won't return into casing.This gives 'Zoom Errors.'
The lens needs to be replaced, or if you can try and SNAP the lens back towards center so it's not at an angle you might be able to fix it. Most likely not though, and you will have to replace the lens.
Thomas
Sep 12, 2011 | Fuji FinePix F480 Digital Camera
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | Olympus FE-46 Digital Camera
The lens will not retract seems to be jammed. It requests that I turn the camera off and restart but to no avail.
The camera is experiencing a lens error and needs to be serviced. Try restarting it a couple of times first but if that won't work, just have it serviced. The site that is great for help with these is: www.camerasandparts.com All they deal with are problems on the powershot cameras and they are wonderful if you need help with one of these. All the best with the problem, that's a nice camera.
Sep 18, 2010 | Canon PowerShot G9 Digital Camera
Lens gets jammed on and off
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Canon PowerShot S1 IS Digital Camera
My camera won't stay turned on
Its possible that dirt, sand had got stuck between your lens barrel and the body and that why the lens is giving you problems.
You can try some of the following solutions to help you out:
1).Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont try very hard please.
Try the above and let me if its any help.
If the above does not help. Then you would need to take it to the nearest service center.
Mar 08, 2009 | Kodak EasyShare M1073 IS Digital Camera
Panasonic Lumix DMC-LZ8K Digital Camera Logo
117 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
