Question about Olevia LT27HVX 27 in. LCD Television
Olevia 242fhd-t11 Has no power. Will not turn on
Olevia 242fhd-t11 Will not turn on , I have checked all outlets, they are plugged in correctly to a power strip.
Everything else on the power strip works.
I switched plug location on power strip, still does not turn on.
The back of the TV is plugged in tight.
I flipped on and off the switch in the back, still no power.
    Problem Solver:
  • 17 Answers
I am guessing that since you are checking other outlets that you are getting no STB light or anything. So you will want to start by looking at the SMPS on the unit and see if the 5A 250V fuse is blown or not. If it is blown then you can try replacing it but I would bet that it will just blow again. So you need to replace the SMPS
Posted on Sep 09, 2010
  • robroy8219 Aug 02, 2011
    In the same boat....but i got mine apart...got the 5a fuse...but how can u tell if it's blown? its all white in the center....
    Problem Solver:
  • 10 Answers
Use an ohm meter to check the fuse. you should get 0.00 ohms or if you have a digital multimeter, set it on diode which is also a continuity tester you should get a steady beep if the fuse is good.
Posted on Dec 06, 2011
TV powers on, but no picture
Have you tested the various power supply voltages along with the PSON or PWR-on voltage, start there
Dec 21, 2017 | Olevia 42" 242-t11 1080i widescreen hdtv...
Need to order parts for my olevia 242FHD-T11 tv
Most likely you will have to order the main board. Not sure if you can just buy the antenna connector
Jan 06, 2013 | Olevia LT42HVi 42 in. LCD Television
My OLevia 265FHD-T11 powers on shows the Olevia logo then goes black what is the problem
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 24, 2012 | Televison & Video
I have a olevia 42 inch 242FHD-T11 it is around 3yrs old and now it will not turn on with the remote so when I turn it on manually it comes on but with no sound after I do this 3 or 4 times the sound...
I am also having this exact same problem... except sometimes the power wont even come on with the power button on the tv. did you figure out what it was?
Thanks
Sep 21, 2010 | Olevia 252T LCD TV
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Olevia LT27HVX 27 in. LCD Television Logo
1,731 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
