Question about Microsoft Xbox 360 Console
E71 system error has appeared on screen with one red ring lit. Does anyone know how to resolve as my machine is out of warranty? Thanks in advance Firefly
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
The way to get around this is to contact Xbox support via phone/email and tell them you have three red lights on your console and your warranty will be automatically extended to 3years FREE and will be booked in for a FREE repair
Tel: 0800 469 9263
Posted on Jan 31, 2010
I have an xbox 360 that pops up with the 3 red lights on the front and every now and then the e71 error. How do I fix this problem myself?
Nobody is 100% sure what causes this error but it Most likely relates to dashboard and console updates. Also, the problem appears to arise from gamers incorrectly flashing their hardware or doing botched firmware hacks which then prevent the system from functioning correctly.
Have you recently updated your Xbox 360 in anyway, or have you (or anyone else) attempted some form of firmware hack or flash? If so, this is probably the cause of the e71 code on your Xbox, however, it could also be completely random. If you call microsoft they will most likely tell you to9 just reset but that is only a temporary fix and you still have the problem of annoying freezes which will get worse and worse. Fixing the Xbox e71 is quite tricky. First try these methods,
1) switch off the console. With the console switched off, press and hold the sync button (the small white button that is used to search for wireless connections). While holding the sync button, switch on the console by pressing the power button and do not release hold of the sync button until the console is fully booted up. During the booting up of the console, any failed updates will be cleared allowing the console to run normally once again and thus eliminating the xbox 360 e71 error.
Another similar way is to
2)Hold the wireless connection button on your controller down with the 360 off. It's the little white button between the shoulder buttons. It's what you used to set up your wireless controller with your 360. While still holding the button, hit the XBOX logo on the controller to turn on the XBOX. Do not let go of the white button. After it's fully started up, you can let go. this reverts you back to your last update.
Or if nothing else seems to work you could try completely resetting your Xbox 360. To do this,
3) First enter the dashboard, go to the right-most column, go and press "Initial Set Up" then follow the instructions on screen. If you cannot access this screen due to the e71 error on your Xbox 360, you can try holding the "Y" button on your controller as you switch the console on. This will enter the same process, and restore default factory settings. However, there is still a chance that this might not work.
There are guides available online for less than $30 if you cant seem to get it fixed but make sure you get one that explains all errors as most only tell about the red ring of death.
Hope this helps
Nov 29, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Sons Xbox 360 shows code E71 what does this mean or the ring of dead...?
hi E71 error code is listed as this fault
E71: Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair
try using both of these reset procedures below to solve the problem, you may lose some game data so you need to bare that in mind.
if the below methods dont work then the chances are it has over heated and you will get the dreaded red ring of death.
if you look at the display where the on button is let me know how many lights you have as this is also an error code.
Clear All Installed Game Updates and Console Cache
1. Go to the "system" blade
2. Select "memory"
3. Press Y on the HD symbol
4. Press X,X, Left Bumper, Right Bumper, X,X
5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
6. Select Yes
Clear Any Failed system updates that cause the console to error.
1. With the console off, press and hold the sync up button (the small white one)
2. While holding the sync button press the power button to turn on the console
3. Continue to hold the sync button until the Console has booted up completely.
4. During the boot process the console should clear any failed updates, allowing you to use it normally.
let me know how you get on ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 16, 2010 | Microsoft Xbox 360 Console
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
Red Ring of Death : 1 Red Light
Well the why part of your question can be answered here - http://www.xbox.com/en-US/search.aspx?keyword=one+red+light
They go into many of the error codes, as to how to fix it without voiding the warranty; If it's under warranty send it in to be fixed, or if you're dying to play right now try the 'towel method' shown here -
http://www.xbox360rally.com/the-red-ring-of-deathcure-found/
Beware- purposefully overheating your xbox 360 may damage your system further.
Please rate my response :)
May 30, 2009 | Microsoft Xbox 360 Console
You may be a victim of software counterfeiting
Hi Shilpa,
Thanks for sharing your problem with details.
there are two reasons for the messege you get,
1. you are using at least one or more pirated software
2. Your system is infected with a deady virus.
To resolve this in administrator login:-
  • Please try to start your system in safe mode (Press F8 while system boots)
  • Try to uninstall undesirable Sw
  • Reboot system in Normal mode
  • control panel --> administrative tools --> Event viewer
  • note down the red indicated errors and notedown corresponding programs/tasks
  • Open task manager and disable those tasks
  • Uninstall the tasks those are reported in error
  • Clean registery using cCLeaner or SystemMechanic
  • update browser and update your messenger
Even if you have problems please write or call me
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 29, 2009 | Microsoft Windows XP Professional for PC
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
