Question about Aiwa PX-E860 Turntable
Can't Remove Platter!
I'm trying to get the platter off to adjust the belt, and I am dumbfounded by the little horseshoe shaped clip holding it down!  Please help!
Are you serious? All you have to do is get a tiny screwdriver and slide the thing off in the logical way (away from where the "horseshoe" is open and horizontal to the platter.
Posted on Jul 31, 2008
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Tip
    Installing a belt on a plastic turntable
    Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it back on so that the post points right over the motor pulley. Now turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. "I like that old-time rock and roll"...
    on Apr 05, 2010 | Audio Players & Recorders
    I just got this turntable, and the platter has a wobble.
    First check that the adjusting screws that stop the turntable moving about during transport are fully open.
    Lift the turntable matt and move the platter by hand. You should be able to see that everything is OK or anything that looks odd. If you still can't see anything wrong remove the platter. First make a note of the belt fits. Take photo's if it looks complicated.
    The platter will be fixed from the spindle. It might have a horseshoe clip holding it. They are tricky to get off, but try. If the spindle has a cover, remove it. If it is glued you can force it off. You can re-glue with Bostick later.
    Examine the platter to see if it is bent!
    Dec 21, 2015 | Audio Players & Recorders
    Platter warped
    Most platters are fixed by a horseshoe clip under the centre spindle. You might have to force-ably remove what is around the centre area to get access to the clip. You can glue it back on if the platter itself is fine and not warped. If it is warped it would be cheaper to get a new deck than search for a new platter.
    Dec 10, 2015 | Audio Players & Recorders
    The turn table on my record player wont spin I can hear that it's on put wont spin.please somebody help
    Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of courseicon1.png, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
    Oct 29, 2013 | Crosley CR249TA Turntable
    I HAVE A PIONEER PL-30 TURNTABLE AND I NEED TO REMOVE THE 'PLATTER' IN ORDER TO REPLACE THE BELT. THERE IS NO CLIP TO REMOVE. HOW DO I GET THE 'PLATTER' OFF. AGAIN THERE IS NO CLIP FOR REMOVAL.
    Pull up on the platter with one hand after you remove the rubber mat. Then hit the center post with a rubber mallet while pulling up on the platter with on hand just hard enough to release the platter from the post. The platter should come off.
    Aug 06, 2013 | Pioneer Audio Players & Recorders
    Turntable does not function
    Turntable Belt... Try to picture this, remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on.
    Nov 01, 2010 | Seth Thomas Pacconi Turntable
    The turntable won't spin
    Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of course, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
    Apr 10, 2010 | Crosley CR248 Turntable
    The belt is off and not sure how to put it back
    OK this may sound funny but try to picture it. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on.
    Apr 05, 2010 | Philco (R) Classic Turntable CD Shelf...
    Dont know how to put on the belt for my emerson turntable m-266oa
    Merely take off the horseshoe clip from spindle(under rubber) and remove turntable. Put the belt around the circular raised area in the middle of the platter and reinstall platter over spindle. align one of the holes in the platter with the brass spindle and just pull belt around spindle. Good luck...
    Jul 10, 2009 | Aiwa PX-E860 Turntable
    Aiwa PX-E860 Turntable Logo
    403 people viewed this question
    Top Aiwa Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
