Question about Sport & Outdoor - Others
We have moved to a new location. Our Proform is located in the garage. Every time we have tried to operate the treadmill, it causes the breaker to "crash" as soon as switch is turned on. How can I trace the problem?
  • 15,935 Answers
What size is the breaker? The treadmill pulls at LEAST a 30A draw.
If your breaker is 20A or even 30A, (especially if there are other items on the circuit) it will trip every time.
Check the fuse on the unit itself - and then you'll require a breaker 10A larger.
Thanks
Posted on Jan 31, 2010
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the...
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
Nov 25, 2013 | Proform 625 Front Roller Model Pftl62510
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
I have a proform 300 treadmill. we moved into a new home and it just stopped working. it was perfectly working before the move. now, nothing comes on, no power, nothing.
Dear Sir:
I will help you.
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
2) Circuit Breaker:
Please check the circuit breaker from the main panel, and reset, or put some Lamp for to see if turn on. if do it. the problem could be the wires and the plug, Test it with A VOM(Voltimeter) for a continuity.
Thank you in advance, sincerely.
If you need extra help, please do not hesitate to reach me. .
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Proform 810 TR Treadmill
How do I move my Proform Treadmill to another room without taking it apart completely. It will not fit thru the doorway and too heavy to lift alone.
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I hope this helps. I am not sure what model you have but i have the 525x. To move it I make sure the incline is set to zero, list the track/running section and lock it into place with the locking pin located on one of the handles. The Proform i have has attached wheels so i lean it back and get it close to the door standing straight up. Once there I turn the treadmill slightly and get one side through the doorway then I pull it halfway through the doorway. If its a tile, wood or linoleum floor make sure to put a rug under the treadmill to protect the floor. It will also helo it slide through the doorway easier. Then tuun the treadmill slightly the other way and get the other half through the door. Once there i tilt it back on its wheels and move it where i want it.
Jun 18, 2010 | Proform Crosswalk 500 Treadmill
I have a proform crosswalk calibre complete treadmill and the incline is not working. I know when it happened before I pressed the reset button and it worked - but I can't remember where the reset button...
Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position
May 06, 2010 | Exercise & Fitness
Was just given a Proform 490GS. It has been
Clean item up real good with damp rag-not dripping wet-dust/dirt will hurt walking platform/belt. Icon.com
Icon is the manufacture located in login Utah. Manuals can be downloaded through internet with model# of item, thats located on a silver tag in frt on frame,or under walking platform/mtr hood area. Proform did make one style that the model# was underneth...but thats been 10yrs ago
Jan 06, 2010 | Proform 490GS Treadmill Walking Belt
Sport & Outdoor - Others Logo
22 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
