Question about Coffee Makers & Espresso Machines
My Solis Palazzo trips EGI in outlet. It grinds fine but when it is time to squirt the water it trips the circuit breaker in the outlet (EGI). What could cause that?
    President:
  • 1,618 Answers
Check the power filter / capacitor under the pump.
Posted on Mar 04, 2010
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
After grinding my machine will continue grinding three or four times every 10 to 15 seconds for about 1 second. Also when I am using the steam wand it will only steam for about 15 seconds and then the low...
Hi
Sounds like you might have spilled some descaling solution on top of the machine. It might have gotten down into the board and is shorting the circuits. I have seen this before. The board might be salvageable but needs to done professionally.
You could be leaking internally and shorting the board.
Dec 20, 2009 | Solis Palazzo Espresso Machine
Solis Master 5000 trips GFI outlet during brewing.
It sounds like the power filter(capacitor) located under the pump is damaged.
Oct 23, 2009 | Coffee Makers & Espresso Machines
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Oct 07, 2009 | Solis Palazzo Espresso Machine
I have a Verona Express VER 1 gs 1 group semi auto coffee machine that allways trips the main fuse when ever i turn on the steam button, if i isolate the wires into the boiler the other parts work and when...
HI
If you disconnect the element wires and the machine works, but when you hook them back up it trips the circuit breaker. Your element is bad (shorted) and need to be replaced.
Jul 30, 2009 | Solis Palazzo Espresso Machine
Solis Palazzo Bean Grinding
That one with number on is finer or coarser grinding beans, the other one is for how much gram it would grind. + means more gram.
I hope this will help you.
Apr 28, 2008 | Solis Palazzo Espresso Machine
Blowing circuit
Most of the part in your machine is that Saeco use in thier machines, i think the boiler is the same.
Dec 19, 2007 | Solis Palazzo Espresso Machine
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
