Question about Dishwashers
Bosch Dishwasher model SHU33AO6UC/22 The sanitation light doesent come on
SOURCE: she47c0 bosch dishwasher won't stop
You're hosed.  This is likely a bad control board module that can run you in excess of $200.  Even if you're within Warranty, Bosch will gouge you for labor, as that is NOT covered by warranty.  Top that with abysmal customer service and you're in for a world of hurt.  Sorry, but it's time for a new dishwasher. :(
Posted on Oct 28, 2008
SOURCE: Our Bosch SHU43C Built-in Dishwasher sticks in the drying cycle.
I have the same dishwasher and started experiencing the same problem last week. It is now fixed (at least for the moment). Here's what I did first. I checked the drain pan under the machine for water(none), the heater for continuity(okay), the float for binding(none), and the float switch for proper functioning(okay). I tried turning the ckt breaker off for a couple of hours to see if that would reset the control module(no effect). I then dissasembled the front door and removed the control module. I had previously read about the common problem of a cold solder joint on the heater relay pin on the control board. My heater was working and the joint looked good but I resoldered it anyway. I reassembled everything and it worked perfectly! My conclusion is that it was either a cold solder joint that was somehow causing the problem or a connector issue that got resolved during my disassembly/reassembly. Hope this helps.
Posted on Dec 31, 2008
here2helpBSH
  • 27 Answers
SOURCE: Bosch dishwasher stuck on '1'/restarts & sanitize not lighting
it possibly could be a bad soldier joint on the heater relay of the circuit board. but if it is then let an authorized bsh tech replace the board since that is a 5 year warrenty part usually. it also could be problem with the NTC-HEAT ASSY- OR FLOW CONTROL. which are all part of the heat assemby.
but the first thing i would check since the time is jumping around on that model would be to make sure that the polarity on the power cord isnt reversed where its hooked up to the d/w
Posted on May 30, 2009
  • 10 Answers
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Posted on Jun 26, 2009
  • 457 Answers
SOURCE: my bosch dishwasher model shu33a keeps
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Posted on Feb 27, 2010
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
My Bosch dishwasher stays running in the wash cycle, will not shut down or dry and sanitize the dishes.Checking the fault codes both the power scrub and the reg wash lights flash. Model SHU33A02UC
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Aug 10, 2010 | Bosch 24 in. SHX33A02 / SHX33A06...
I own a bosch dishwasher model SHU33AO6UC and the problem is that water comes at the bottom although the machine is off
Thanks!
Aug 04, 2010 | Dishwashers
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Not drying and sanitize light is not coming on. Dishes are WET
is it draining ok? Are the cycles really long? if yes it might be a control module problem also found on other models.
Bosch Dishwasher Stuck on 2H
bosch dishwasher troubleshoot manual
I soldered mine. works.
keep us updated.
Nov 05, 2009 | Bosch Evolution 300 SHE33M05UC Stainless...
May 27, 2009 | Bosch Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
