Question about Singer Sewing Machines
My touch tronic 2001 needle won't move, therefore, won't feed. I have it on Normal, I tried resetting it, I even tried to walk it manually.
5 Suggested Answers
  • 14 Answers
SOURCE: changing needle/thread
Yes, you have to remove the walking foot, the threading mechanism does not have electronic recognition of different feet so when you add a foot that has a different fitting you will have to remove it to self thread.
Gale
Posted on Mar 23, 2008
  • 1788 Answers
SOURCE: How do I rewind the
you can go to www.tandtrepair.com and they show lots of free things for your machine, like winding the bobbin etc. Also, you can order a hard copy of your manual from Singer, 1-800-4singer for $15 or download one for $12 from www.sewingmanuals.com and pay through paypal. You have lots of choices. Good luck, Happy New Year
Posted on Jan 02, 2011
  • 111 Answers
SOURCE: Have a Singer Touch-Tronic 2001.
On many of these machines, the bobbin case gets gouges in it. Try a need bobbin case.
Posted on Apr 25, 2011
bargainbox
  • 1388 Answers
SOURCE: ihavea touch tronic 621 machine the needle will not pick up the bobbin thead so i cant stitch
Try new needle first, then....look HERE for generic advice as to timing:
If over 2 years since last service, ....too long
Posted on Nov 02, 2011
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
The needle on my singer touch tronic will not move. Does it need oil. How do I do that?
I believe that is an older mechanical machine. If it hasn't been cleaned and thoroughly oiled recently, most likely it is seizing because the moving parts are frozen. Refrain from trying to run the machine until you get the issue the addressed or it may damage the machine and/or motor.
Jul 23, 2017 | Singer Sewing Machines
I have singer touch tronic 2001. I was wondering if a HD needle size 18 work on this sewing machine
Yes, you can use a size 18 needle in the TouchTronic 2001. See page 15 (page 21 of the PDF) of the manual. The PDF is available here: http://www.singerco.com/uploads/download/66946ce4f503e17bfd20036aef30c05707c736e1.pdf .
You should only use a heavy duty machine needle (2020-18 or 2032-18) with a heavy cotton mercanized or synthetic thread when those are appropriate for your fabric. You should always match the thread to the needle. The thread should fit in the groove on the front of the needle. If the thread is too thick or thin compared to that groove, you can have problems with tension.
I hope this helps.
Mar 01, 2017 | Singer Sewing Machines
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Needles Won't move
Sounds like a boss jam? Recalibrate to needle one, Reset for each mfg is different.
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Toyota Sewing Machines
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
May 08, 2008 | Sewing Machines
Sewing Machines Logo
120 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
