Question about Dell Inspiron 6000 Notebook
Computer crashed Dell inspiron 6000 shows blue screen saying technical information 0x00000024
Hii,
As you wrote that your system is giving an Blue Screen Error message. Firtsly I would like to tell you that try and swap the memory sticks and try and power on the system on one memory stick. This will help us narrow down the root cause. If the system is working on one memory module then the fault is with the other memory module, and if in case the system is giving errors on both the memory sticks, then it is sure that the Motherboard and the memory sticks have gone bad and needs replacement.
also you can try and run a daignoistics on the laptop, it might give an error message.
If you see an error message after running the daignostics contact Dell Tech Support as they can replace the parts that are mentioned above.
Thanks & Regards
Kunal Sharma
Posted on Dec 10, 2008
  • 4 Answers
HI,
You can always check your error numbers on microsoft's web site. They will post how to make your memory dump bigger so next time you install that program you were waiting to see. You won't get the blue screen of death.
Posted on Feb 21, 2008
  • 72 Answers
That is a memory dump, try to remember what hardware or software did you install or uninstalled recently, if you can log-in on windows try uninstalling or reinstalling the hardware or the software. if it fails, run the windows recovery on the cd and repair the windows installation.
Posted on Feb 18, 2008
Dell inspiron 570. 1 beep on start up. black screen. 1 light on the front
if you need support for your Dell inspiron 570, Blue Screen of *****, Fix Blue Screen Errors, Blue Screen Error in Computer, Blue Screen Error in Laptop, Dell Technical support Number, Dell computer support, Dell laptop support Number 1-800-204-4427 (toll-free) and more... http://www.delltechnicalsupportphonenumbers.com/blue-screen-of-*****
Jun 24, 2017 | Dell Computers & Internet
My Dell mini Inspiron 10 shows a blue screen at startup
BSOD! blue screen of death....most common in windows vista, your gonna need to get into the recovery part of your computer on boot up, try to hit/hold f11 on boot up to get to system recovery tools
Jun 17, 2013 | Dell Inspiron Computers & Internet
My computer is stuck in a roboot loop. i have windows xp OS. it suddenly shutted down n when i start my computer now, it shows me a blue screen with message that a problem has been detected and windows has...
a_mamatha
If you can reply back with the error message as well this will better help me see what is going on with your computer. If you look at the link below it will show you the info that I looking for.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
Apr 14, 2010 | Dell Computers & Internet
My Dell 1525 has a blue screen when switching on, says config_list_failed, I've switched it off & back on but just says the same, Technical information at the bottom says ***stop: 0x00000073 &...
from these errors, the hard drive is full and the system is out of virtual memory which is gotten from the pagesys, you need to get a new drive,, a blue screen is crash if you have a windows OS
Mar 09, 2010 | Dell Inspiron 1525 Notebook
***STOP:0x00000024 (0x00190203, 0x8A811CA0,
Could be a number of problems, including but not limited to...
1) NTFS file structure is corrupt
2) MBR has been compromised (corrupt)
3) ATA/SATA drivers are corrupt
4) Hard drive is on the way out
Boot your computer using the OS install disk, and run CHKDSK /f from within the recovery console. CHKDSK /p will repair a corrupted NTFS file system (if that's the problem).
If CHKDSK options don't fix the problem, or if the drive is not recognized by your OS, it may be your MBR (Master Boot Record). Use the command fixmbr from within recovery console, then reboot.
MBR may be data destructive, so it's best to use CHKDSK options first. Also, if you are able to get the system to boot up, you'll want to save/recover any data on the hard drive, then run thorough diagnostics on the drive to make sure it's not on the way out (contact Dell for further information regarding this).
Hope this helps!
Aug 16, 2009 | Dell Inspiron 6000 Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Dell E310, XP2 Home Edition
Its mostly because of bad hardware or wrong drivers try to reinstall win dows with clean drivers if it doesnt help. then its problem with some hardware like memory or hdd. if u need drivers u can find them here
If it was helpful rate fixya
Dec 27, 2008 | Dell Dimension E310 PC Desktop
Black screen
Try to reinstall XP again, when prompted to partiton, select to do so.
You will lose everything on the hard drive and will need to reinstall all of your programs.
Hope this helps.
Good Luck.
Nov 28, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000
If you purchased your I6000 after 2005, then it still has the PC Restore option. For Dell system with Windows XP, your can restore your computer to factory settings by pressing CTRL+F11 when you see the page after the big DELL Logo. It's a BLACK SCREEN with a blue bar at the top and it has www.dell.com written in white. Usually this screen will show up in between the DELL Logo and Windows Logo.
Nov 22, 2008 | Dell Inspiron 6000 Notebook
6000 crashing
sounds like your motherboard fried
Sep 06, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
196 people viewed this question
Alun Cox
