Question about Mitsubishi WD-62525 62" Rear Projection HDTV
No picture tv comes on with a bright blue screen. No picture, just sound.
  • jaquar Feb 22, 2008
    Hi
    And yes I too have the same problem, Tv turns but no video, sound is ok.
    I've check all the cords, everything is ok, I get a pink screen with horizontal
    lines. My email address is h_ramos001@yahoo.com
  • alfabob Feb 28, 2008
    Here's what to do: Select Menu/Setup/AV Connection/Locked to Input 1. Yours probably says Yes. Change to No.
  • 42 Answers
Somehow you have your inputs not on... but don't get ahead of ourselves. Check the cables in back... The video cable in... make sure it is fully connected from cable box / satellite box to input, then make sure the input is on where it is plugged in.
Posted on Mar 12, 2008
Hisense TV - right half is blue
change your tcon board and you will be fine
Oct 06, 2017 | Televison & Video
T.V. comes on show blue then goes out after 3 second and only hear sound
When it comes on with a blue screen is it rather bright and or has curved faint trace lines in the picture?
Dec 12, 2012 | Sony KP-65WV600 65" Rear Projection...
Sony television,model number KP51HW40,serial number 9026465,the problem is turn on the tv within in 30second the screen come to blue but sound is coming,no picture
If you are saying it goes to a bright blue screen I can tell you what to try.
This model has a history of bad picture tubes--red,green and mostly blue.
The blue screen can be turned down and I can tell you how.
The way you will know if this is your problem is take the set to a unused video input--all you should see is video 1 etc in green; if you see blue with or without trace lines you have the problem.
Let me know what you find and if so I will tell you how to adjust the set manually to try to correct it.
SD TECH
Aug 17, 2010 | Sony KP-51HW40 51" Rear Projection...
I get sound but no picture
If the screen went dark blue, this is the way that sets mute the video to protect the tube. However If the screen is very bright blue with possibly blue lines going through the screen, either the blue gun in the CRT has failed which is unusual but can happen or the driver transistor/IC which drives the blue gun has gone short circuit. If you know how to use a meter, you can perform a comparison check by comparing say the red O/P TX with the blue O/P TX. Ian
Jul 23, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Our 1991 RCA P52150CP rear projection TV has gradually been getting bright cloudy blue, slight haze around letters & shapes-(especially blue channel change headings) when first turned on and then it...
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run you about 300 to 500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
http://servicemanuals.vstore.ca/
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
