Question about Apple iPhone Smartphone
I cant exit safe mode and i tried like 1000 times... i need some help...
I cant get my phone out of safe mode and when I want to hold the power button for options like power off or restart it goes straight which means I cant follow the instructions on how to exit safe mode...
When you hold the button down to get to the power off window, keep holding the button down til the screen goes black and it reboots. If that doesn't work, try taking your battery and sim card out of your phone , put them back in and turn phone on......
Jan 18, 2015 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Reboot acer aspire 4752g laptop to exit safe mode. network diagnostics cannot be run in safe mode
If you download Hirens (Google it) boot disc or USB (150mb file) you will need to USB key installer from the same site and select USB or cd to start first in bios.the boot disc loads a small version of windows Xp on you memory ram.this is as good as safe mode.when the page fully loads you can gain internet access that way .there are hundreds of tools on this programme to fix all kinds of problems and get your laptop up and running.
Dec 10, 2014 | Acer Computers & Internet
How do I get a vw jetta 2008 out of safe mode 2?
Usually has to be left switched on in safe mode for several hours before the code can be retried.
Aug 26, 2014 | Cars & Trucks
My Ps3 is stuck in safe mode.
Hold down the power button for 5 seconds or until you hear a beep. It will reset the system.
Jan 26, 2014 | Sony Playstation 3 (PS3) Console
My hp mini 1000 has a virus i cant log on or nothing it says safe mode it didnt work tried f11 key still nothing.help please
can you tell me a little more, does the computer actually go to sign on screen? what happens after the bios screen loads, does it blue screen, I can help I just need a little more info :)
Mar 18, 2013 | HP Mini 1000 Netbook
My 1998 vw beetle its stuck on 2 safe mode i need help getting that out thanks
First of all you should exit from 2 safe mode. Then turn ON the radio and let it turned ON for at least one hour, in order to exit from 2 safe mode.
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of VW radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Sep 13, 2011 | 1998 Volkswagen Beetle
I have a 99 a6 quattro i have the code for the radio but when i press rbds and pscan buttons nothing happens it is in safe mode and wont let me do the steps to get out of it!
First of all be sure that your four digit security radio code is correct. If you had attempted three times without success to exit from safe mode by inserting the code, radio is blocked in safe mode for a while. Now turn ON the radio (in safe mode), and let it turned ON for one hour, then follow this procedure.
The sequence of VW radio gamma programming is:
Jul 30, 2011 | 2000 Audi A6
2001 Audi A4 radio in safe mode. Battery was
sorry to say, you will need to take it in, it needs to be hooked up to their computer to reset and have it start up poperly. It just like a pc when it crash it will try to start in safe mode until you select "Normal" start up
Oct 13, 2009 | 2001 Audi A4
Harmony 1000 in safe mode?
The harmony remotes have a built in safe mode, similar to a Windows XP computer. Usually you enter the safe mode on the harmony remotes by taking the battery out, then pressing the power off button and holding while putting the battery in. If you continue to press the power off button, the remote will display safe mode on the screen.
If you are not doing the above procedure and you are still getting the safe mode on the display of the remote, I would try to update the firmware on the remote. And if you have an RF Extender, update the firmware on it at the same time.
Hope this helps,
81
Dec 19, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Blank screen with cursor
MS-DOS edit command help This would bring up a blank edit screen, as long as the file is saved upon exit
Click on the above link , Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell Inspiron 1000 Notebook
Apple iPhone Smartphone Logo
203 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
