Question about Toshiba CZ36V51 36" TV
After power button is turned on the led light flashes, and the only way I can get a picture is to bang on the front of the tv by the power button.
  • Toshiba Master
  • 12,061 Answers
Sounds like you have a "Dry Joint" or bad connection, or even a faulty power switch.. this is a fairly common one... try a switch replacement first? Or look for a bad joint on or around the switch connections.
Posted on Jan 30, 2010
No image. seems to be a led problem
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ·This will reset the TV in order to fix the problem.
    ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Dec 06, 2013 | Sharp LC60LE810UN 60 in. LCD TV
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Toshiba CZ36V51 36" TV Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
