Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr/dvd if the dvd works shouldn't the vcr work too. This is what is confusing me
  • Yve 57 Feb 18, 2008
    I am on a satelite dish for tv view. Now does the vcr have to be connnected by a cable to this or to the television? If to the television I would have to get one of those connectors with two joiners or whatever you want to call them. Would the cable be the problem??
  • 2,130 Answers
Both the DVD and VCR sections are mechanically different and separate. They may share some common circuitry. It is very possible to have one part not working, while the other part works just fine.
- Jim
Posted on Feb 18, 2008
  • SHARCNET-USA
    SHARCNET-USA Feb 18, 2008
    My question to you is does the DVD/VCR have a built in tuner?
    Option #1
    If it does, you can connect the cable from the output of the satellite dish box to the RF input to the DVD/VCR player and then you must connect an RF cable from the RF output jack of the VCR to your TV. The TV will need to stay on either channel 3 or 4. The satellite dish box probably comes out on either channel 3 or 4 so you will need to tune the DVD/VCR player to receive channel 3 or 4.
    or
    Option #2
    Instead of an RF cable to the TV, you can connect the a audio/video (yellow/red/white) cable from the audio/video jacks of the DVD/VCR player to the audio/video input jacks on the TV and set the TV to use the audio/video jacks and not it's RF tuner.
    You will still need to set the DVD/VCR player to receive the output from the satellite dish box if its coming out on channel 3 or 4.
    or
    Option #3. Connect the satellite dish box RF cable directly to the TV. The TV's tuner will need to be set at the proper channel to receive the output from the satellite dish box (channel 3 or 4).
    Connect the audio/video cable between the audio/video outputs of the DVD/VCR player to the audio/video inputs of the TV. To watch a DVD or VCR set the TV to monitor the audio/video input jacks. To watch TV, switch back to the tuner.
    Please let me know if I can be of further assistance to you.
    - Jim
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
Is it possible to copy video from a vhs to a dvd?
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
Jul 05, 2011 | GoVideo DVR4000 DVD Player/VCR
Need to turn on DVD/VCR unit inorder to view the TV.
Hi there, You shouldn't have to turn on the DVD to view the TV only. But if you have it in AV1 mode or DVD then you will, coz it's trying to operate thru the DVD unit. Hope this helps, tho it's been a while since you asked?
Jul 14, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
VCR audio connection from DVD/VCR combo, DVD works but VCR doesn't have audio, new machine.
I finally called the customer help on phone # and got a nice person to help me. She walked me thru the wire connection and it worked. I had tried that connection before but not with the way the TV wires were connected. There are so many ways for connecting but only one works for both the DVD and the VCR for audio and that is straight down on 7. White, Red, Yellow. The wording on the paper is very confusing and I had tried so many connections on the TV end, that is where my problem was. I am glad it works and comes in great. Also I don't think I was hitting the change button on the remote. When I did it on the machine it worked. I still haven't figured out the remote buttons yet. I will by the end of today.
Dec 04, 2009 | Funai Televison & Video
Philips DVD750VR will not load DVD or cleaner CD
When my dvd player starts doing this it usually means that it is going bad and you may need to replace the dvd.
Jan 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
My brand new Magnavox ZV450MW8 DVD recorder drawer is locked (or broken). Customer help can't tell me how to unlock it. Anybody know?
dear Deemom,
you said yours is the new one. so y are you breaking ur head to open them. just contact your nearest srvice center. They must solve the prob.
Sep 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Dvd player problem
check your lense condition it may need to be cleaned if there is any dust buildup.
Sep 27, 2007 | Daewoo DV-6T955B DVD Player/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
