Question about Dell Latitude D510 Notebook
Turning on the laptop it tells me missing operating files misssing, not all the time?
  • Dell Master
  • 12,061 Answers
Sounds to me as if you have hard drive problems perhaps crosslinked files or the drive is going flaky, I suggest you run, the disk tools and check your drive also give it a "Defragment" too. Right click on the hard Drive Icon, and choose "properties" then "Tools" run the "Error Checking" tab.. let it complete and follow any instructions, you may have to reboot so it can do it's work, after which go to same menu and run the "Defragment" program
Posted on Jan 31, 2010
When i turn on laptop i get a reading ,"window failed because system registry file missing or corrupt.have no back up disk.how can i fix?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
if you need more help with this poat a reply
hope this helps
Aug 26, 2011 | Compaq Computers & Internet
When i turn it on it says ntldr is missing
To repair missing orcorrupted system file/s, please click on this link and follow my instructions :- http://www.fixya.com/support/r4482455-repair_windows_xp
Nov 18, 2010 | WYSE X90L Laptop
When i boot hte computer the ntldr is misssing???
you might have accidentaly deleted th ntldr boot application. one way to solve this without formating your harddrive is; take out your harddrive and put it in to the computer as a slave drive with same operating system and copy the ntldr file. this file actually located at the C:\ drive and is actually hidden. just tick all show hidden file under folder options then VIEW TAB inorder to view and copy this file to your harddrive. once done, take our your harddrive and set again the jumper settings to Master then put it in to your computer. power on the computer and it should be working after this procedure. Else fails, you need to use the recovery disk that came with the system and restore the computer back to its factory setings.
thanks and have a good day!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 06, 2010 | Microsoft Windows XP Home Edition
NTDLR missing
Hi Friend,
NTLDR file is the part of operation system,this is hidden file of window operating system,some time if system restart between the work or some one delete this file,in this condition you need to reinstall the operation system,please reinstall the window operating system.
If you ned any help for installation .......please tell me...
Thanks,
Feb 03, 2010 | Toshiba Satellite U205-S5002 Notebook
Hi,i have problem with my laptop when i installed any o.s. in my laptop then it was not boot from cd it will show message ntldr file is missing what should i do pls tell me
ntldr file is needed to boot a system
it will installed when you reinstall your operating system
but be aware don't delete that file it will in the OS drive
Dec 31, 2009 | Acer Computers & Internet
My system won't boot because the windows\system32\config\system
If i am from Singnet technical Helpdesk, we are advised to direct you to Acer Service centre if you owned an Acer computer with a serial number and if it is still under the warranty period on Operating system missing, Another option is to contact Microsoft service centre for CD replacement or oprating system advise since they are the suppliers and vendors for fathering the operating system, To troubleshoot your missing files,you need to know pecifically which files are missing and are they registered in your O/S and are they active and running or are they deactivated, takes longer time to solve missing files problems because you did not list what files are missing and you need to tell microsoft what files are missing in our operating system as there are thousand of files in the WIndows operating system
Jul 23, 2009 | Acer Aspire One AOA150-1983 Notebook PC
Laptop will ot boot
do you have the cd? if so do what its saying on the screen there if you do not have a cd and it didnt come with one then you will need to access the hidden partition of your harddrive that stores the operating system files and to do that veries from each computer if you have a manual for it then it will tell you how most of the time its a key you press when it first turns on such as F10 or F 12 it will probly tell you when you first turn it on what to press but if not look it up in the owners manul
Apr 12, 2009 | HP Compaq Presario V2000 Notebook
IRIVER H10 system files misssing
you can just go into the shop you bought it from or dicksmiths or something and they would sell the disc
as for your computer one just plug in your device then when you think it has loaded and everything go in to my computer and it should have your device there!
Oct 12, 2008 | iRiver H10 MP3 Player
Missing or corrupted files
get the 98 start up floppy and stick it in the a:/
Copy command.com, or anything else missing to your c:/ from the floppy. type help/? at the c:/ and you should find the proper format for the version of DOS you have.
C:/copy a: c:
Oct 21, 2007 | Computers & Internet
Dell Latitude D510 Notebook Logo
Alun Cox
