Question about DeLonghi DCH4120 SafeHeat Ceramic Compact Heater
Temp doesn't shut down when preset temp reached. Have to do it myself. Set it for 62 for example, won't come on till I set it to maybe 70. Try to set the temp to maybe 65, doesn't shut down till we manually set it to maybe 60. Temp setting not very accurate. Anything I can do?
    Scholar:
  • 185 Answers
This is normal. It will only turn on when the temperature set is below the ambient temperature in the area around the thermostat.
Your problem may be the location of the thermostat is not ideal form the areas you are heating. this usually cause the temperature in areas vary from the thermostat to the point wher relocation of the thermostat is sometimes the best resolution.
this is often the case wher ther are multiple heating zines in a building, and one or more zones interfere with the thermostat of others,
but it also happen in single zone heating systems too.
Posted on Jan 30, 2010
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Furnance will not start until room temp is at least 5 degrees below set temp ie temp set at 70 , wont start till it reaches 66 or 65 degrees
themostat is bad, or the heat anticipator on the stat is bad, which means you still need a new stat
Oct 23, 2010 | Heating & Cooling
My ge Model # ASM10AKS a/c intermittently seems to be blowing smoke condensation or gas into through the house vents. I looked through the problems and solutions and did not find this problem. What is it?
Try setting the ac to a higher temp setting. Idealy above 70 degrees. I set mine a 75. If it does that at higher temp setting then maybe it is caused by the ambient condition. For example in the morning because the air is cold but humidity is high. Check if the compressor cuts off when it reaches cut off temp. Also check to see if ice is building up on the evaporator.
Jun 26, 2010 | GE ASM10AC Air Conditioner
My ac will not stay on when its at a certain temperture or auto. only if its in on position
this is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Jul 31, 2009 | Heating & Cooling
Tried resetting the thermostat. Shows 70 degrees for a second. Then back to 78.5 degrees. When I use the arrow adjust to change settings the number does not change
Depends on your Tstat. The set point is different from room temp. My tsat show set point and room temp. But to answer you when you set at 72 and room temp is 75 . It will go back to room temp till you reach that temp. Rusty
Jun 07, 2009 | Heating & Cooling
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
DeLonghi DCH4120 SafeHeat Ceramic Compact Heater Logo
193 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
