Question about Broderbund The Print Shop 20 Deluxe for PC
HAving trouble loading Print Shop 2.0 on Vista
  • 12,061 Answers
Install & Run in Computability Mode for XP SP2. This may help.
Posted on Jan 31, 2010
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
Jan 30, 2010 | Broderbund The Print Shop 20 Deluxe for PC
I am having trouble with booklet style printing -- under Vista
After a great deal of frustration and trying every permutation possible I succeeded amid an ever rising mountain of paper! . . .and find that I have to totally ignore the "Booklet printing" option . . . but ask it to print landscape; 1 page per sheet; flip on short edge.
Now I need to do the same to crack the sytem for the Cannon Pixma IP4000 inkjet.
Thank you for your consideration.
Sep 30, 2009 | Brother HL 5150D Laser Printer
"Print to File" WTF is this?
put the hammer down and step away from the printer lol. The problem you are having is directly related to the computer not "seeing" or recognizing the the printer. Sure you installed the software and drivers probably not the right ones. With Vista you have to use Vista specific drivers.
The unfortunate thing is that after reviewing your make and model of product at the Konica Minolta global site there are no available Vista Drivers for down load. Check here for your self
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=PagePro%201350W
This leave only 2 options - contact Konica Customr service and see if there are driver available by some other means ( althought they will prob tell you to download them) or Upgrade to a new printer.
Sorry for your luck :(
JB
May 18, 2009 | Konica Minolta PagePro 1350W Laser Printer
Trying to reinstall vista; it goes about 75% then hangs
if you are reinstalling from a dvd...its just probably having trouble in reading the files from the disc...try another disc...and also ..try to format the C partition before loading files...it might recognize some old files...and misguide itself..
Apr 28, 2009 | Computers & Internet
I am fairly new to PCs. I recently purchased a Toshiba 205 and have Vista SP1.  I purchase Print Shop Delux 22 and started the installation process before I read the statement about don't start...
Hello, Encore Software has released a patch to make Print Shop Deluxe 22 compatible on Windows Vista.
Here is what they say here:
http://support.encoreusa.com/kb.asp?id=571
Problem I am looking for the Vista compatibility patch. Solution This Windows® Vista update will detect and repair The Print Shop® 22 and PrintMaster® 17 applications already installed on your computer. After applying this update The Print Shop® 22 and PrintMaster® 17 will operate normally on computers running Windows® Vista.
Update Instructions
1. Click the link located at the bottom of this page.
Note: For Microsoft® Internet Explorer® the File download dialog may appear. Select Save this program to disk and click OK.
2. Choose a location (e.g., the Desktop) and click Save. The download process will begin.
3. When the download is complete, close the Download window.
4. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update.
5. Follow the onscreen instructions to complete the installation.
Note: Depending on system or user account settings, you may encounter several interruptions during the installation process. If so, please click Continue or Allow in order to proceed.
6. Launch and use The PrintShop® 22 or PrintMaster® 17.
Click here to download Broderbund_Print_Update.exe (26.7 MB)
Aug 21, 2008 | Computers & Internet
Broderbund The Print Shop 20 Deluxe for PC Logo
351 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
